Results 1 to 10 of 10
Thread: Replaced heater core, only cool air coming out
    Dec 2009
    Default Replaced heater core, only cool air coming out
    Hey all,
    Just finished a heater core on a st184 celica. To my dismay there is still only cool air coming out of the vent. Strangely enough one of the hoses going into the heater core is hot yet the other one is still icy cool...
    Im suggesting there is a block somewhere in the core/heater tap at the moment.
    I will check if its actually getting past the heater tap (by checking the hose just after it)
    Any suggestions on the topic?
    ZZT-231 Toyota Celica SX
    Default Re: Replaced heater core, only cool air coming out
    Sounds like the tap isn't working correctly. I'd be very surprised if the core was totally blocked. They usually leak before that.
    Apr 2007
    wilcannia NSW
    there may be air in the heater core. one way is to take off one of the heater hoses, then fill the radiator using a funnel which seals in the spout.
    the idea is to get a column of water a bit higher than normal to help push out the air. pour in water ( coolant ? ) until water comes out of the heater. put the hose back on and start 'er up. works wonders.
    hope this makes sense.
    did you reconnect the cable for the cold/hot dial?
    its probably full of air, I've had systems take > 30 mins with the engine running before the heater spat out hot air again
    I am the sun
    me too but only on nissans, fords, commodores, benzes, BMWs....never happened on a toyota for me.Random....
    Dec 2009
    Thanks for the suggestions, it ended up being air in the system.
    The first time when I went to switch off the car with the cap off there was a huge burst of air come through,
    Then I went to rebleed the system just earlier and there was so many bubbles, ive never seen so much in a toyota before.
    I got to the car wash this afternoon and noticed I had left the top radiator hose was loose., I may have to bleed the system again to bring up the heat a bit (its still not quite boiling hot air yet)
    Rep to all the great suggestions thank you
    Over the course of 2 - 3 heat cycles it will purge the air via the overflow bottle.
    Generally to get water to flow up and through heater cores the system needs to be pressurized. Ie. the cap needs to be on
    I am the sun
    Tallahassee, FL USofA
    Quote Originally Posted by trd_st184 View Post
    It needs flow from RPM, pressure from being heated/capped won't matter in pushing out air.
    Fill it, drive it, top it off, that's it, and only dick around with bleeding if it can't be started & the customer isn't going to top it off.
    Heater core replacement 101, before connecting heater hoses back to the engine, use a garden hose to force water into the heater core and expell the air. Then connect all hoses, that is how the radiator repair shops do it.
    The humble 1.25 ltre PET softdrink bottle (screws into most radiators) with the arse end cut out is perfect for getting a column of water above any air entrapment points in an engine. Some engines actually have air bleed points near the thermostat, worthwhile checking your repair manual for tid bits like this.
    cheers Chuck.
    MS51Crown Coupe,
  1. Heater Core Alternatives
    Last Post: 28-10-2007, 09:43 PM
  2. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 06:08 AM
  3. Radiator question.. Core thickness/air flow
    Last Post: 05-05-2006, 09:49 PM
