Results 1 to 15 of 17
Thread: 2jzgte vvti injectors vs RX7 850cc injectors
    Mar 2009
    Auckland
    Default 2jzgte vvti injectors vs RX7 850cc injectors
    hi guys i need some help. does anyone have a picture of 2jzgte vvti injectors? or some measurements?
    i brought some 850cc rx7 injectors they fit in the rail but i think they may be a bit short and the side feed is not exactly on the middle of the rail.
    http://media.photobucket.com/image/r...l/IMG_0361.jpg
    i have the brown/red colored ones. im thinking just a spacer under the injector might do the job
    Sydney N.S.W
    Default Re: 2jzgte vvti injectors vs RX7 850cc injectors
    what the chances of a part number of injectors for the 2j?
    If the brown is what you bought, whats the yellow one then?
    Mar 2009
    Auckland
    brown are rx7 injectors(primaries 850cc) the yellow are also rx7 injectors but the secondaries. i dont have part numbers for the injectors but google and it should have the info you need supraforums has a thread dedicated to it i just cant find it atm
    part number 23209-46100 for VVTi injectors
    Just to let you kow that there isn't any difference (Bar the colour) for VVTi 2JZGTE injectors vs non-VVTi ones that I know of
    Wilbo's JZA80
    Wilbo's JZZ12
    Mar 2009
    Auckland
    i think that is wrong wilbo http://www.nzperformance.co.nz/store.../prod_142.html
    lists the injectors for a 2jz and the vvti seperately.
    also http://www.supraforums.com/forum/sho...+injector+flow has pictures of the vvti and the non vvti injectors and you can see the slight difference in the height of the injectors above the o ring.
    i will have a non vvti rail tomorrow so i can measure and fit the injectors but from over the phone measurements it seems the non vvti rail is about 4 mm taller and that about what i need for the injectors and collars i have to fit. and the non vvti rail seems like it will fit vvti runners. i will confirm this tomorrow tho 100%. but so far this is looking good
    i will take pictures side by side and measurements with a caliper tomorrow but im confident i have fixed the problem fingers crossed
    Interesting, I'll look into that when I get a chance
    Wilbo's JZA80
    Wilbo's JZZ12
    Mar 2009
    Auckland
    yea rail didnt turn up yesterday damn well beta be on my door step this afternoon or else!! then ill do a write up about it
    2JZGTE VVTI injectors part number 23250-46100
    Jealousy is a curse
    Sydney N.S.W
    it's so weird, the 23250 number is nippon denso, but the 0E30 number is a Jecs injector code.
    Mar 2009
    Auckland
    ok so i was asked to finish this thread. the rx7 injectors will fit a 2jz rail but will need collars to space them up so that the inlet of the injector is inline with the feed rail of the fuel rail. when you use a collar the injector itself sits just above the rail but it still seals the fuel in 50+psi at idle.
    also the 2 rails vvti and non vvti are the same i took measurements and they are both exactly the same. anymore questions?
    Club Member Grease Monkey
    mr75: hey got a pic of the collars and where they sit?
    how thick is the collar?
    will sr20 side feed injectors work?
    they are also high impedance
    thanks
    Mar 2009
    Auckland
    Quote Originally Posted by exquisit View Post
    thanks
    here is a picture of the collar http://img294.imageshack.us/i/injector1km9.jpg/
    the collar is just enough to sit the injector feed in line with the rail feed about 15mm from memory. if you have a picture of your injector i could possibly tell you.
    hey mate
    heres a pic of sr20 injectors
    if you need me to put a ruler next to one let me know
    Mar 2009
    Auckland
    hey mate
    umm there is no pic mate
  1. 2JZGTE VVTi wiring diagrams and ECU pinouts
    By 98SZR in forum Tech and Conversions
    Last Post: 02-07-2009, 11:55 AM
  2. 2JZGTE VVTi Timing Belt Installation, Help needed!
    Last Post: 20-11-2008, 04:05 PM
  3. 2JZGTE ETTC Guide (VVTi included)
    Last Post: 24-08-2008, 11:15 AM
  4. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
