Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Aftermarket ECU maps for 7MGTE
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Aftermarket ECU maps for 7MGTE
    Hi all.
    Currently installing my Haltech E11v2 into my 7M supra.
    Does anyone have any maps for the 7M to suit any ecu (I'll download software and copy the values) so I can just get the car running.
    My setup:
    Sequential Injection
    Standard Coils, Wasted Spark
    Standard CAS/CPS (24+1 multitooth)
    550cc injectors
    CT26E highflowed
    16psi
    So if anyone has anything I can cross reference the setup with and use the fuel and ignition as a rough base map so i can get it running, it'd be great!
    Email me any maps at [email protected]
    Thanks!
    Ryley
    Gearwhore. Backyard Mechanic
    Oct 2008
    Default Re: Aftermarket ECU maps for 7MGTE
    If I'm not mistaken there was a map floating around on here for a 7MGTE with an Adaptronic.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Forum Contributor Domestic Engineer
    I don't have my maps with me, but should be able to get them in a day or two from my mechanic.
    Setup was 7MGTE / Adaptronic, running the standard sensors bar ignitors, map, and lack of AFM. CT26 highflow @12PSI, with standard injectors and fuel pressure.
    I was probably be going to see him today anyway, so hopefully I'll remember to chase it up.
    FWIW, he actually used a previous map of a 4AGZE with a T28 as a base to get mine running as they had similar compression, ign timing and boost response curves. Once the timing of events was changed to include the extra 2 cylinders, the thing started and ran.
    Might be worth looking into if you can find a haltech on something else, as then you don't have to worry about differences between software?
    Call Haltech up.
    They emailed me out a base map for a 20v when i needed it.
    Excellent, thanks all! I'll call up Haltech, look for some 4AGZE maps and await boxhead's goodies!
    Well Haltech have none, so anyone with a similar base map would be great!
    would hardly call it similar
    but google the tuning thread started by todd - jza70r
    if thats nto good enough, give me your email and i can send u mine for ems 8860. cars not really stock though but should get u going
    Signiture edited..... Read the Rules
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    mine has a haltech e6x tuned to 180kw, i dont really know how to get the tune off it tho, but can get it done if u want
    yeah i've read that thread, very handy. if you could still email me your map it'd be great! email is in first post
    ecko, afaik it's pretty simple to get he map off, plug in computer, load up halwin software, connect to ecu, download/save fuel and ign maps. if you've got a laptop and 9 pin connector it's dead easy. would be awesome if you can be stuffed getting it coz i think the e11v2 can simply import e6x maps!
    thanks all
    May 2007
    tasmania
    find me the software and cable and ill do it
    edit got software,
    hmmm cable i think ya can get from a computer place? ill direct deposit you some dough if you want for it? provided it;s not spastically priced?
    i nicked one from an old 386 lol
    May 2007
    tasmania
    hmm can u find me a ebay linky for one and ill order one, ill need one anyways
    May 2007
    tasmania
    ordered a 9pin to usb cable hopfully it'll work
    Sorry Ryley, I've been a bit slack.
    I'll try and get onto him tomorrow for you.
    awesome guys, thanks very much. most appreciated
  1. 1UZ aftermarket ECU option??
    Last Post: 04-08-2011, 09:07 PM
  2. 1GGTE TVIS + Aftermarket ECU and BB Turdbro
    By Kedderz in forum Tech and Conversions
    Last Post: 31-01-2009, 09:18 PM
  3. 3sgte ecu error code??? and afm????
    By paulioq in forum Tech and Conversions
    Last Post: 30-09-2008, 03:55 PM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
