Results 16 to 30 of 37
Thread: Aftermarket ECU maps for 7MGTE
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Default Re: Aftermarket ECU maps for 7MGTE
    how will a adaptronic tune work on a haltech?
    It wont.
    Well... the ignition map could be manually copied across, but the fuel map could only be used as a rough reference.
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    yeah i was going to manually copy both figures for X load at X rpm, and then richen and retard the fuel and timing respectively to get it safe
    just so i can drive 15 mins down the road to the dyno and get the thing started and running
    Nope you wont be able to straight copy the values for the fuel map.
    For the ignition map, yes, but not the fuel map.
    The values mean pretty much nothing between different brands (and even types) of ECUs.
    You need a proper Haltech base map.
    May 2007
    tasmania
    well mine should siut then, motor is standard albut recently rebuilt, tune is for 7psi so should be fine only prob may be its a e6x not the e11
    that's crazy, i didn't know that! i know the haltech has the values in mS, so I just assumed from there?
    Thanks mate, good info
    Ecko- Mine is prety much standard (bigger turbo, injectors, boost) so will be quite helpful. I'm pretty sure the E11v2 can import E6X maps!
    Thanks all, rep given
    May 2007
    tasmania
    just waiting for the cable to turn up mate should turn up today hopefully
    that'd be awesome man thanks
    May 2007
    tasmania
    didnt turn up soon hopefully
    May 2007
    tasmania
    cable turned up but i cant get it the pc to communicate with the haltech,
    halwin just stays in offline mode
    hmmm thats a bit gay! what version of windows and halwin are you using? you might need some software thing to make the haltech software look at the usb port rather than serial, ie trick it... maybe ring haltech?
    thanks though mate
    can anyone tell me what tooth offset and trigger angle they are using for the stock 7m CPS?
    May 2007
    tasmania
    using windows 7 but it should work
    Low rep 1st year Apprentice
    Feb 2010
    western australia
    Cool Re: Aftermarket ECU maps for 7MGTE
    Dont suppose you have a 8860 base map for a 4agze ?
    May 2007
    tasmania
    nope,
    but i cannot get halwon to talk to the haltech
    that's really weird... i had trouble back in the day with an E6, i had to restart in msdos mode... don't think windows 7 and halwin wouild like that though haha
    check com port - usb drivers, and what com port it is using?
  1. 1UZ aftermarket ECU option??
    Last Post: 04-08-2011, 09:07 PM
  2. 1GGTE TVIS + Aftermarket ECU and BB Turdbro
    By Kedderz in forum Tech and Conversions
    Last Post: 31-01-2009, 09:18 PM
  3. 3sgte ecu error code??? and afm????
    By paulioq in forum Tech and Conversions
    Last Post: 30-09-2008, 03:55 PM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
