Results 31 to 45 of 53
Thread: 1UZ Coil-on-plug conversion
    om nom nom Backyard Mechanic CheeseBiscuits's Avatar
    Default Re: 1UZ Coil-on-plug conversion
    So apart from wreckers or ebay, where are people sourcing the 3UZ CoP units?
    I figure I may aswell do CoP when I go adaptronic.
    Quote Originally Posted by CheeseBiscuits View Post
    I assume this is for your 3S-GTE?
    I use 1NZ-FE (Toyota Echo) COPs on my 3S-GTE and they are perfect.
    ([][][]II--LT--II[][][])
    I've sourced some from here for the 3sgte - the 1nz ones are what I have used - I think I got that info from one of your posts? Cheers mate.
    This is for my 1uz Cressida
    wreckers, ebay (US) Yahoo.jp or Amayama, whatever works
    Cheers mate.
    So part number would be 90919‑02230?
    might have to order some of these asap.
    May 2009
    Cheers mate.
    Anyone got a part number for the clips/plugs on these 3UZ Coils?
    May 2009
    thanks mate
  9. #39
    I sell coil-pack connector kits for $5 each with the housing, seals and connectors- although they are not genuine.
    http://s-86.com/s-parts-coil-plugs.html
    Of note I took a faulty coil apart and the plastic outside does not provide an insulation at all, that is taken care of inside the melal housing under the plastic, go grind away as you please.
  10. #40
    subscribed for future reference.
  11. #41
    Currently designing a plate setup to mount 8 LS coils on 1UZ's for people with aftermarket ecus. Had trouble with turbo 1UZ tonner with std coils and leads so went down that path to sort it out. Plates should be cheap and LS coils are $200 a set these days.
  12. #42
    Will an Autronic CDI500R unit control the LS coils Al?
    I have both but the current plan was to use a set of Honda CDI CoP I have. Buggers don't fit without some stuffing around and still some question how much boost they will spark...especially with E85.
    As far as I have heard the LS coils will take whatever boost is thrown at them with no miss issues
    Nov 2011
    By ls coils does he mean Holden ls1
    They have internal ignitor so u cant run a cdi and u dont need external ignitor
    Just run ecu ignition triggers directly coils
    I just wired up a wolf 550 into a supercharged 1uz and we ran 8 ford ba bf 6cyl coils
    With an m&w ignitor
    Fit ok just the top plastic part is abit tall so u have to make special brackets to hold em in
    But think we were pushing for over 600 hp
  14. #44
    SM2 won't run the LS igniters by all accounts.
    Rush Imports 1st year Apprentice
    Jun 2008
    LS2 Truck Coils from the USA are way better than the LS1
  1. MA61 5me to 5mge conversion guide
    By Enchanter in forum Engine & Driveline Conversions
    Last Post: 17-09-2013, 06:07 PM
  2. Hilux 1uz conversion
    By mick08 in forum Tech and Conversions
    Last Post: 20-02-2009, 04:09 PM
  3. 4AGE coil on plug conversion
    By TERRA Operative in forum Tech and Conversions
    Last Post: 07-11-2008, 09:13 PM
  4. MA70 --> JZA70 Conversion
