Results 1 to 7 of 7
Thread: 7mgte idle/vac problems
    victroia
    Default 7mgte idle/vac problems
    hi guys i have a 7mgte in my bundera, its been in for a while now and running fine until recently.
    its got some vac issue where it will running fine some times then it will start running really rough and die between gears or at the lights and then some times after long drives it will start revving harder
    the reason i was thinking vac issue was i can see the vac gauge drop when the issue pops up, but i would have thought if it was just vac it would be like it all the time
    this then made me think idle control valve, so i replaced it (with second hand) and now it revs it absolute guts out? so maybe this ones shagged as well?
    any one have any ideas on what could be causing this or had similar issues?
    thanks paul
    victroia
    Default Re: 7mgte idle/vac problems
    now it idling better but seems really rich on idle, blowing black smoke everywhere, still not driving right, it seams now as if the idle is coming up and down when back off
    i'm running out of ideas and starting to stress me out lol any help would be great
    thanks again
    senior backyard mechanic Grease Monkey legend's Avatar
    give the pcv valve and pipes a clean they can block up
    building my 4agte ae82
    victroia
    alright ive cleaned the pcv system, the idle control valve and the maf sensor. its running heaps better, but now it got this weird thing where when there just a bit of throttle on (like cruising sort of throttle) it revs up and then dies and revs and dies again, so when driving it stutters and carries on to the point that it will actually stall
    thanks paul
    edit: it also back firing a bit, sorta after reving it hard?
    Dec 2009
    how old are the vacuum hoses?
    victroia
    id say they 90% would be original, that might be an idea i suppose, i'll see if i can replace them tomorrow
    victroia
    fitted new maf sensor today, was sorta on a hunch as cleaned it again and it got worse, but its running like brand new now, thanks for the help guys
    paul
  1. 7MGTE & W58 into auto MA61
    By Supra6 in forum Engine & Driveline Conversions
    Last Post: 20-02-2007, 09:17 AM
  2. 7MGTE Headgasket Problems
    By Mundoolun in forum Tech and Conversions
    Last Post: 28-11-2006, 08:56 PM
  3. Sam's MA61 7MGTE Conversion
    Last Post: 09-11-2006, 11:08 PM
  4. Problems solving 4agze
    Last Post: 28-06-2006, 06:21 PM
