Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Oil Pressure light on startup
    Nov 2007
    Default Oil Pressure light on startup
    When I start my car, I get the oil pressure light come on for about 1 or 2 seconds after the engine has just started. But it never comes on during driving, only during startup, plus I hear a bit of a grinding noise on startup.
    Just wondering could it be a failing oil pump and could it cause any damage?
    Thanks.
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    Default Re: Oil Pressure light on startup
    Change your oil filter, sounds like the anti-drainback valve has gone (allows oil to drain out of the filter when standing, then takes a few seconds to fill the filter back up).
    Jul 2009
    very common for the oil light to be on for 1-2 seconds its based on pressure and as the car has only just started the pressure isnt there straight away, and just as an fyi most oil filters don't have an anti drain valve in them. check on the ryco site to see if the one they make for the 1g does.
    From experience nothing to worry about. the grinding noise is probably your starter motor
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
    Not trying to be a Carport Converter
    Jan 2009
    usually if you hear noise on startup and you suspect its oil pressure related, it can be valvetrain noise, until the oil gets up to it. This happens usually after i've done an oil/filter change and the filter is filling up. Also happened when i was running ryco filters instead of toyota.
    Nov 2007
    Thanks,
    Yeah the noise seems to be coming from the head. If the filter doesn't have an anti-drainback valve, could this be the cause of the light coming on for 1-3 seconds after startup?
    It has been doing this not just after oil changes but all the time.
    Jul 2009
    what brand oil filter are you using
    2009 Ford Fiesta LX
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    Normal on some vehicles. My 5SFE Celica does it every time. The manual even says only to worry if the light does not turn itself off after 30 seconds (Which is ages!)
    Jan 2009
    could also be low oil level (i had this issue when my dizzy was pissing oil and i got lazy checking the level)
    Nov 2007
    Brand of oil filter is Ryco.
    Oil Level is good, on the full line.
    I used the same oil filter on my other Soarer/1g-gte and I didn't get the check engine oil light.
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Sounds normal to me it will come on until oil pressure feeds the swtich to turn the dash light off.
    Nov 2007
    Ahh ok,
    Just seems weird since my old car didn't do that.
    Could a blocked oil pickup cause this problem?
    Eltham vic
    another thing to consider use a good quality oil
    i had a 528 bmw with a few k on it and the light would stay on for a couple of seconds , and it loved oil , until i put a genuine filter and gtx in it , by the time it needed a ltr of oil it was due for an oilchange any way
    Junior Member Grease Monkey toyoda's Avatar
    I would strongly recommend unscrewing the RYKO and looking inside.
    Just because.
    Toyoda
    West Australia
    My 1JZ/5MGE/1GGTE/2LT and my housemates 3L / 1JZ
    all do it
    because it takes 1 second for the oil pressure to be high enough for the light to go out
    if you have a grinding noise does this only happen on cold start (in morning after its been sitting overnight ?)
    If so, the drainback valve could be the issue, or your running shit oil.
    my 1JZ in the drift soarer does it without fail if ive let it sit overnight and start it the next morning.
    Nov 2007
    Yeah usually overnight when i let it sit i get the grinding noise when its fully cold.
    I use Mobil1 Oil 15-40.
    Today when cold it turned on without any the light staying on, but other times the light will stay on for 2 seconds or 3.
  1. Aftermarket oil pressure gauge stuck/issue
    By thepeter in forum Tech and Conversions
    Last Post: 09-03-2009, 12:24 AM
  2. Fresh 2tg hybrid no oil pressure at idle
    By 2TG KE35 in forum Tech and Conversions
    Last Post: 20-08-2007, 01:02 PM
  3. Replies: 8
    Last Post: 18-08-2006, 04:52 PM
  4. AE82 100kw motor Shift Light Install
    Last Post: 29-12-2005, 11:22 PM
