Results 16 to 17 of 17
Thread: knocking 3sge - bearings?
    Default Re: knocking 3sge - bearings?
    Hmm I guess a piston out of it would be ok, the head looked pretty grubby though
    The damage really is pretty minor as the screws are only tiny, it basically just looks like a few scratches. I'm going to clean things up properly today and have a better look
    I am the sun
    i would probably be doing it all properly and make sure that nothing is bent/warped. Unless that screw was flattened on the first impact (which it clearly wasn't) it's going to have done some damage. Basically that screw has been squashed between the top of the piston and the flat part on your cylinder head. Then it's exited the engine through the valves. Potentially you could have a cracked piston, bent rod or even bent valves. At least get those checked before putting it back together. I also look at getting the head checked to make sure its nice and flat.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 10:15 PM
  2. 3SGE differences?
    By Ashe in forum Tech and Conversions
    Last Post: 04-04-2007, 06:46 AM
  3. 3sge main bearings
    Last Post: 18-02-2006, 10:43 PM
  4. More 4-to-5 stud hub conversion data
    Last Post: 19-01-2006, 01:40 AM
