Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: Synchronic BOV's, Wastegates, FPR's
    Nov 2007
    Default Synchronic BOV's, Wastegates, FPR's
    I've just been reading about Synchronic BOV's, Wastegates and Fuel Pressure Regulators.
    Here is a link about the Synchroniv BOV/BPV
    http://synapseengineering.com/smf/in...na7&topic=30.0
    Also some Video Demonstrations on Synapse Engineering Youtube Channel :
    http://www.youtube.com/user/synaptic1
    Default Re: Synchronic BOV's, Wastegates, FPR's
    Quote Originally Posted by synapseengineering
    Turbo is spinning many thousands of RPMs at engine WOT (wide open throttle) -> throttle shuts -> pressure builds up between closed throttle and still spinning compressor wheel -> pressure has to go somewhere so it stops the spinning compressor momentarily to pass air over and over again -> So you hear tsssch tsssch tsssch tsssch -> each successive tsssch is air passing the compressor wheel out the inlet of the turbo in the other direction from where it is supposed to go -> Turbo slows down and stress is put on the common shaft because you have to remember that the exhaust is still torquing the turbine wheel to spin the compressor.
    Well, I ain't no expert, but last time I was off the throttle in either of my turbo'd cars, I'm pretty sure that there wasn't any exhaust gas "still torquing the turbine wheel to spin the compressor".................
    ok.... so in your turbo car, when you throttle off, your motor stops??? ie produces no exhaust at all... because the exhaust has to flow past the turbine wheel (unless the wastegate is open - which it wont be off throttle) to get out of your motor.
    Not argueing for or against blow off valves.... simply responding to that response....
    Stew
    Quote Originally Posted by Toy77 View Post
    Stew
    How much exhaust gas do you think the engine is pumping out when the throttle is closed?
    Closed throttle = very little air into engine = very little fuel into engine(probably zero from the over run fuel cut off that most engines have) = SFA exhaust gas. Not zero, but certainly not enough to be spinning a turbine wheel with any great force.
    If an engine with a closed throttle was still moving enough air to turn the turbine wheel with enough force that the turbo could generate boost pressure, then there would be no such thing as turbo lag and the turbo would be acting like a positive displacement supercharger.
    that wheel still spins pretty quick at idle, you wouldnt want to put your di@k in it......
    i wasnt argueing for or against a blow of valve - you said there was no gas......
    the idea isnt that it is still making boost, but rather has a force (though small) as well as momentum that keeps the wheel spinnin off throttle - the air trying to escape from the system has to go back the opposite direction past this wheel.
    Jul 2007
    yes it's the momentum which gets it. the bov stops this build up of pressure which the still spinning turdbro creates.
    From what i can understand from that link, the synchronic valve doesnt close completely on idle. I had this problem on a normal piston bov (spring was too soft) and as such more air was leaked into the system, more fuel was added to compensate and as such would lead to farting around idle as it was trying to compensate and sometimes would stall the engine on the way back down from high rpm to idle. Wouldnt this still have the same problem?
    Mr Shabadoo.
    Daily JZX100
    There's no build up of pressure from the still spinning turbo...how can it make more boost from less energy being put into the system (bugger all exhaust energy driving the turbine)? Defies physics eh
    You'll get a mass of moving air hitting a closed throttle plate, you'll get a pressure wave reflection off the closed throttle plate, you'll have a pressure differential across the compressor wheel and little energy driving the wheel and you'll be way below the surge line on the compressor map. Just for info, when air speed stalls across a turbine the turbine will speed up, not slow down as many state.
    So, all these things lead to the various choof, wizz, tssch noises you hear when getting off the throttle.
    There's little to no stress to the turbo, unless you are running massif boost and a big turbo. Recirc BOVs are there OEM for noise reduction only. I've yet to see a single independent test showing a BOV does anything else but make silly noises, including data logging done by myself.
    Now synchronic WGs, they sound interesting
    Aug 2009
    a blow off is a blow off.... that blow off has an extra port to put extra load on the diaphragm inside it..
    blow off valves are used to let pressure build up escape thru a safe exit rather than going thru the pipes and trying to escape out the air filter via going thru the turbocharger the opposite way...
    cant really even see how this is a thread?
    Banned 1st year Apprentice
    Jan 2018
    Default selegiline deprenyl buy buy deprenyl selegiline
    CLICK HERE TO BUY deprenyl ONLINE RIGHT NOW!!!
    » Really Amazing prices «
    » NO PRESCRIPTION REQUIRED! «
    » Top Quality Medications! «
    » Discount & Bonuses «
    » Fast and Discreet Shipping Worldwide «
    » 24/7 Customer Support. Free Consultation «
    Related Tags:
    deprenyl selegiline buy
    http://www.galdon.net/base/librodevi...tarios=http:// ephedrine cafeine aspirine buy
    http://deutschland-im-mittelalter.de/Krankheiten aciphex pariet buy discount
    http://www.kathleenmullaneydds.com/ seretide serevent buy ventolin inhaler no prescription seretide diskus
    http://bioinformatics.mdanderson.org...forum/st/id77/ where to buy viagra in ethiopia
    http://www.alternativakz.com/?guestbook buy cetirizine hydrochloride tablets buy cetirizine walmart
    http://garden.academic.ru/forum.rss cheapest atorvastatin in india buy atorvastatin calcium tablets
    Jan 2018
    Default monodox buy monodox buy generic
    CLICK HERE TO BUY monodox ONLINE RIGHT NOW!!!
    Try Also:
    monodox for sale
    monodox buy generic
    monodox buy
    monodox buy
    monodox buy
    monodox buy generic
    monodox for sale
    monodox buy
    monodox buy generic
    monodox for sale
    monodox buy generic
    monodox for sale
    monodox buy
    monodox for sale
    monodox buy generic
    monodox buy generic
    monodox buy
    monodox for sale
    monodox for sale
    monodox for sale
    monodox buy
    monodox for sale
    monodox buy generic
    monodox for sale
    monodox buy generic
    monodox buy generic
    monodox buy
    monodox for sale
    monodox buy
    monodox buy
    monodox buy
    monodox for sale
    monodox buy generic
    monodox for sale
    monodox for sale
    monodox buy
    monodox for sale
    monodox buy generic
    monodox buy
    monodox buy generic
    monodox for sale
    monodox buy
    monodox buy generic
    monodox buy
    monodox buy generic
    monodox for sale
    monodox buy
    monodox buy generic
    monodox buy
    monodox buy
    monodox buy
    monodox buy generic
    monodox for sale
    http://xn--sjq315a.lineage.one/forum...d=12427&extra= atasol codeine over the counter
    http://singaporesale.sg/find-new-markets-in-china/ the cost of a plan b pill duramed pharmaceuticals the cost of the plan b pill duramed pharmaceuticals
    https://www.copywriteri.cz/blog/ buy plan b contraceptive progestin buy alesse online estrogen and progestin
    http://www.ghbfm21.com/bbs/forum.php...=408444&extra= zyloprim cost buy z
    http://www.everydaycn.com/mypage/? vistaril atarax over the counter
    http://www.gaestebuch.pferdesportfes...dex.php?go=add ring order pills actos actos cheap price
    http://www.infoelectro.ru/auth/add_exhibitions cost depakote divalproex sodium what is the cost of depakote without insurance
    http://www.moskitus.ru/test.aspx?preview=1 buy cheap cialis daily how much does daily valtrex cost
    Jan 2018
    Default flutamide buy online flutamide over the counter
    CLICK HERE TO BUY flutamide ONLINE RIGHT NOW!!!
    Try Also:
    what is the cost of flutamide
    buy topical flutamide
    buy flutamide online
    cost of flutamide
    where to buy flutamide
    flutamide cost
    cost of flutamide
    where can i buy flutamide
    flutamide cost
    cost of flutamide
    cost of flutamide
    cost of flutamide
    flutamide cost
    flutamide cost
    flutamide cost
    flutamide cost
    flutamide cost
    flutamide cost
    cost of flutamide
    flutamide cost
    cost of flutamide
    cost of flutamide
    flutamide cost
    flutamide cost
    https://wiki.bzflag.org/index.php?ti...edit&redlink=1 atasol codeine over the counter
    http://www.kathleenmullaneydds.com/ how much does combivent cost canadian pharmacy combivent
    http://www.clubcantabrico.com/v_port...s/apartado.asp buy aricept online alzheimer's aricept cheap
    http://www.bike-peijian.com/index.ph...=index&a=guest actos pioglitazone hcl buy actos pioglitazone hcl order
    http://www.xfbaojing.com/thread-1411-1-1.html where can i buy prednisolone online prednisolone acetate cheap
    http://www.makemoneykenya.com/cgi-bi...iate-marketing cost of generic uroxatral buy uroxatral alfuzosin
    http://ciaservices.com/cia-board-mem...sk-experts.php levoxyl without a prescription eltroxin order synthroid online eltroxin
    Jan 2018
    Default is warfarin an over the counter drug cost of warfarin therapy
    CLICK HERE TO BUY warfarin ONLINE RIGHT NOW!!!
    Similar Keys:
    cost dabigatran vs warfarin
    apixaban vs warfarin cost
    pradaxa cost vs warfarin
    order warfarin online
    warfarin drug cost
    warfarin sodium for sale
    warfarin testing machine for sale
    cost of warfarin management
    what over the counter medicines can the drug warfarin interact
    warfarin tablets cost
    cost of warfarin 5 mg
    warfarin cost in australia
    the cost of warfarin
    cost warfarin vs dabigatran
    warfarin over the counter drugs
    what is the cost of warfarin
    warfarin online cheap
    cost of genetic testing for warfarin
    monthly cost of warfarin
    generic warfarin cost
    warfarin where to buy
    what does warfarin cost
    how much does warfarin cost at walmart
    warfarin cost per month uk
    cost of warfarin in canada
    cost of warfarin in india
    which over the counter medicine can warfarin interact
    buy warfarin tablets
    which over the counter medicines interact with warfarin
    cost of pradaxa vs warfarin
    warfarin monthly cost
    cost of dabigatran versus warfarin
    warfarin sodium cost
    cost of warfarin treatment
    warfarin cost australia
    warfarin and tramadol cheap
    daily cost of warfarin
    warfarin over the counter interactions
    what herbal over the counter medication can interact with warfarin
    over the counter medicines that interact with warfarin
    which over the counter drugs interact with warfarin
    cost of dabigatran vs warfarin
    buy warfarin online
    buy anticoagulant coumadin warfarin
    warfarin cost in india
    how much does warfarin cost without insurance
    warfarin zero order kinetics
    dabigatran vs warfarin cost effectiveness
    cost of warfarin monitoring
    can i buy warfarin over the counter
    warfarin order kinetics
    pradaxa vs warfarin cost
    purchase warfarin test strips
    buy warfarin uk
    http://www.infoelectro.ru/auth/add_exhibitions ramipril nhs cost ramipril 10 mg cost
    http://mireferido.com/inicio_EN.php buy wellbutrin sr 200mg cost of wellbutrin sr
    http://www.gdsri.cn/guestbook/ silagra india no prescription needed where can i get diflucan without prescription
    https://forum.borsato.nl/discussion/631/abertuponed amaryl for sale cost of amaryl in india
    http://sochiinfopress.ru/item/1906-%...%BC%D0%B0.html cheap caverta online sildenafil citrate buy generic caverta
    http://caihongfupin.com/bbs/forum.ph...d=42132&extra= phenytoin first ord
    http://blog.segway.com/20160531welco...-u-s-4760.html 30 mg cost prevacid naprapac
    https://wiki.bzflag.org/index.php?ti...edit&redlink=1 dulcolax over the counter bisacodyl 5 mg
    http://www.shangpuzhuangshi.com/thread-1481-1-1.html purchase neobrufen order neobrufen
    https://leadingedgephysio.com/blog/2...47/about:blank buy letrozole femara letrozole and acne buy nolvadex
    Jan 2018
    Default how much is zyban without insurance cheap zyban australia
    CLICK HERE TO BUY zyban ONLINE RIGHT NOW!!!
    Similar Searches:
    zyban buy online wellbutrin sr
    zyban online no prescription
    buy zyban in uk
    walmart zyban cost
    cost of generic zyban
    cost of zyban in south africa
    buying zyban in the uk
    buy zyban tablets uk
    cannabis buy zyban
    zyban over the counter
    order zyban online canada
    cheapest zyban online
    is zyban over the counter
    canada buy zyban
    zyban cheap drug
    zyban without rx
    buying zyban thailand
    no prescription buy zyban online
    zyban without rx
    buy zyban quit smoking
    average cost of zyban
    without prescription cheap zyban
    buy zyban uk
    buy zyban dogs
    buy order zyban
    buy zyban internet
    zyban to buy tricyclic antidepressants
    for sale of zyban
    is zyban sold over the counter
    cost of zyban in uk
    zyban paypal
    zyban buy online dry mouth
    zyban without prescription
    cheapest zyban
    zyban to cheap
    zyban to buy withdrawal symptoms
    zyban for sale prescription
    tab buy zyban
    how much does zyban cost with insurance
    purchase zyban online
    zyban over the counter uk
    zyban australia cost
    how much does zyban cost without insurance
    c nmr buy zyban
    buy zyban nicotine replacement
    cost of zyban in uk
    150mg buy zyban online
    zyban wholesale
    zyban cost south africa
    zyban purchase
    zyban cost ontario
    zyban more drug_uses cheap
    wholesale zyban
    buy zyban book
    http://www.17portal.ru/trade-page-addform.php seasonal allergy relief buy zicam allergy nasal gel buy zicam
    http://blog-o-bitrix.ru/bitrix/sozda...a-na-bitrikse/ buy apo-prednisone
    http://www.zidoz.com/forum.php?mod=v...id=4308&extra= can i buy avodart in canada cost of generic avodart
    http://www.moskitus.ru/test.aspx?preview=1 prednisolone acetate buy omnipred
    http://xn--h1aeehbklebo.xn--p1ai/forum/add_topics.html cost of pentoxifylline buy pentoxifylline uk
    http://chayadaresort.com/webboard/in...577/1521066944 ventolin inhaler cost singapore buy ventolin us
    http://www.seoagencysydney.com.au/sydneywebdesign/ order prednisone non prescription how much does a bottle of prednisone cost
    Jan 2018
    Default cheap sumatriptan tablets buy sumatriptan online
    CLICK HERE TO BUY sumatriptan ONLINE RIGHT NOW!!!
    Similar Searches:
    walmart sumatriptan cost
    where to buy sumatriptan nasal spray
    where can i buy sumatriptan tablets
    sumatriptan injection buy online
    sumatriptan over the counter in us
    average cost of sumatriptan
    sumatriptan canadian pharmacy
    sumatriptan injection cost without insurance
    sumatriptan cost per pill
    buy sumatriptan boots
    sumatriptan mail order
    buy sumatriptan online cheap
    sumatriptan over counter uk
    sumatriptan cost australia
    generic sumatriptan no prescription
    sumatriptan injections for sale
    sumatriptan cost walgreens
    sumatriptan to buy
    how much does sumatriptan cost without insurance
    buy sumatriptan 100 mg
    buy sumatriptan 50mg
    how much do sumatriptan injections cost
    can you buy sumatriptan in mexico
    sumatriptan cost cvs
    can i get sumatriptan over the counter
    how much is sumatriptan without insurance
    cost of sumatriptan nasal spray
    buy cheap sumatriptan
    cost of sumatriptan injection
    sumatriptan injection for sale
    sumatriptan cost in india
    sumatriptan nasal spray cost uk
    sumatriptan succinate cost
    sumatriptan vial cost
    what is the cost of sumatriptan
    buy sumatriptan uk
    can you get sumatriptan over the counter
    sumatriptan succinate over the counter
    buy generic sumatriptan
    sumatriptan over the counter australia
    is sumatriptan over the counter
    sumatriptan succinate buy online
    sumatriptan 100mg tablets cost
    http://sochiinfopress.ru/item/1906-%...%BC%D0%B0.html nexium order pantozol
    http://iichan.hk/cgi-bin/../d/ buy nolvadex-d astrazeneca nolvadex-d buy
    http://bbs.tkworld.cn/forum.php?mod=...id=4495&extra= mifepristone and misoprostol online buy how can i buy misoprostol
    http://www.managersonline.nl/nieuws/16422/ order terramycin terramycin buy online
    http://www.arroudeya.com/component/o...func,thankyou/ diabecon buy himalaya buy diabecon
    http://theburningbush.org/20.html buy nizoral pills fungal meningitis over counter antifungal cream ketoconazole
    http://www.papa998.cc/forum.php?mod=...tid=613&extra= zaditor cost ketotifen fumarate
  1. Wastegates - Is it important to have a brand-name one?
    Last Post: 28-01-2009, 01:08 PM
