Results 1 to 15 of 22
Thread: JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    Default JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    The 2JZGE VVTi that i bought for the Supra helpfully came with the ECU for it as well. But i have no idea of what car it came out of, and hence the pinouts on the ECU. Here it is though:
    Engine is a stock front sumped version, and the wiring looks to be power through the body loom within cabin, rather than the Supra style of power through the body loom near the fusebox in the engine bay.
    I cant see any alternator wiring on the engine loom, so im going to assume thats body loom too (makes life easy ).
    Anyone able to identify what ECU it is? Better if you can give me the wiring diagrams for it too, but ill settle for knowing what ECU and car it came from.
    Junior Member Grease Monkey Mr.Phreak's Avatar
    Feb 2007
    New Zealand
    Default Re: 2JZGE VVTi - ID my ecu.
    JZS155 Crown from memory, although you may want someone to confirm
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Thats from a jzx100. More than likely a grande.
    1994 GZX90 Mark II 1GZ-FE V12
    Jzs155.................
    Jealousy is a curse
    Seems that it is a JZS155.
    Now how about those wiring diagrams.
    Default Re: 2JZGE VVTi - ID my ecu and wiring diagram needed JZS155
    open the ecu, from my experience the pins should be labelled on the PCB
    with that you can make a pin out diagram
    EDIT: open both sides of the ecu as u might open the wrong side and think they are not on there
    Nope, they arnt. I already tried that one rob. Unless i just cant see them, will open it up again though.
    Default Re: JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    I think i just found them, squirrelled away on a Thai site, and my Thai isnt good (i know Google Fu instead) but i found references to JZS155, and the numbers of pins on the plugs seem to match.
    http://gallery2.plebeians.net/v/cars...hlightId=28369
    Perth WA
    Send me your email, I send you a pinout diagram, problem solved.
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Hey fellas, Ive now got Takai's old engine/ECU/etc. Looking for the same info.
    Have sent a few PMs around but no luck at this point. Little help?
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    May 2006
    NM, found it
    Funny how that works....
    May 2010
    Moscow
    Got the diagrams too, pm me if anyone needs em
    Apr 2013
    Florida
    I am in desperate need of a JZS155 pinout. Please send the link to my email: [email protected]
    Also, the early JDM 2JZGE VVTI motors appear to be non DBW and from what I'm hearing do not have immobilizer chips in the ECU's. Can anybody confirm this?
    Thank you
    Nov 2011
    the early 2j vvti are fly by wire but still cable operated to throttlebody
    then its fly by wire from one side of throttle body to the other side which is where the motor is
    and yes they dont have immobiliser in them
    May 2010
    Moscow
    no they aren't dbw
    early jzs155's (pre-1997) have 4-connector ecu and they are not dbw, though they have 2nd (TRAC) butterfly in the throttle body. Some of the early jzs155's are 5spd (A350), I have wired one. Seems like extremely rare. Later JZS155's are dbw with etcs-i throttle (and ultimately 5-connector ecu), but pedal sensor is still cable operated. None of them have immobilizer.
  1. KE70 Wiring Diagram
    By Pdawg in forum Tech and Conversions
    Last Post: 04-06-2007, 08:27 PM
  2. Needed! - RA63 Wiring Diagram
    By Spectre in forum Tech and Conversions
    Last Post: 06-09-2006, 11:54 AM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 01:29 PM
