Results 1 to 5 of 5
Thread: wiring question auto trans
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    Default wiring question auto trans
    A mates got a GA70 that hes got a jza70 auto frontcut for the conversion. question is the ga70 was manual ( yes why wouldnt he just keep the car manual? he wants auto ) how hard is it to wire up the auto trans?? i have done the conversion before in my supra but i used the r154. never touched the auto's.
    wa
    Default Re: wiring question auto trans
    Surely you could just swap over the whole ecu and loom from the jza70 half cut to the ga70.
    western aus
    okay thanks! but after getting off the phone to him i thought he said he got a auto frontcut but he only got ex jza70 1jz with auto box and all the bits soo that means hes only got the main engine loom, ecu ect is it still possible to get the auto running easy enough?
    Nov 2007
    I persume its an A340 trans
    I think they run a seperate ecu
    you could create a switch system that activated the solinoids, effectively manualy shift it?
    A340s have 3 solinoids, 2 for shifts 1 for lockup( for certain models)
    We have a box (switch box) at work we use to manualy control the auto so to eliminate the cars trans ecu for fault finding.
    Junior Member 1st year Apprentice spencer's Avatar
    Jul 2007
    Hamilton
    Ive wired up a few jza70 ecu's. The auto's controlled by the main engine ECU
    The main engine loom has the auto plugs on it running down the back of the engine, unless someones cut them off. Should basically be a plug in affair concerning the auto, only wires he should have worry about are the ones in the body plug speedo wires, OD switch etc.
  1. Using air con condenser as auto trans cooler
    Last Post: 28-09-2017, 04:40 PM
  2. TA22 Auto v's Manual Trans tunnel size
    By 4SFED in forum Tech and Conversions
    Last Post: 04-08-2009, 07:08 PM
  3. Re22 turbo Auto Trans
    By mux in forum Tech and Conversions
    Last Post: 28-03-2007, 10:52 PM
