Results 1 to 7 of 7
Thread: having some battery troubles..
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    Default having some battery troubles..
    hi everyone. i'm having some trouble with the battery in my hiace van
    the car has been sitting around for at least a month or 2. but i'm having some trouble with the battery.
    i realised the battery must have gone flat when i put my alternator back on the engine today. went to turn the car over and there was nothing. no lights or anything came on. so i got out the battery/trickle charger and connected it up
    was looking at it with my voltmeter. and got some wierd numbers:
    with out the charger and with earth and + hooked up. was getting .003V or something
    with the charger and earth and + got 3V
    with out the charger and earth taken off got 9V
    with the charger and earth taken off getting 11 - 12V
    so how come i'm getting no volts when the earth and that is all hooked up. but as soon as i take the earth or positive off i get 8 - 9volts? i obviously need to let the battery charge a bit more but was just a little confused as to why it was doing this?
    Default Re: having some battery troubles..
    When the battery terminals are on, stuff will be trying to draw from the battery hence the low reading
    I am the sun
    Completely disconnected batteries can show 10-12V and then completely die under even the smallest load, usually either the battery is extremely discharged or it has dropped a cell or two.
    Junior Member Backyard Mechanic KARNAGE's Avatar
    it might also give you a reason why the battery is fully dead, something might be draining it since you have next to no volts when + - hooked up.
    Junior Member 1st year Apprentice 4age_fun's Avatar
    Jun 2009
    Best to take your battery somewhere and get it tested. battery shops, auto stores will do it on the spot for free.
    Mar 2009
    if you know any one with a battery charger . chiuck it on for like 2 hours and then try it again... check the reading after like driving a bit and it it slowly depleting then your batts gonee .. wreckers got em cheap . eg pick and pay
    Forum Member 1st year Apprentice raffy73's Avatar
    May 2009
    Have the battery tested or test it yourself.
    1. Charge your battery first using your trickle charger. It may take a few hours. Charge it until its indicated as fully charged on the charger or if the battery is equipped with a 'magic eye' this should be green. Just for safety, no sparks or flames near a battery that's on charge!
    2. After its been fully charged, check how much voltage its got. If you have (or can borrow) a battery load tester use it. Otherwise leave your voltmeter hooked up and crank the engine while paying attention to how much voltage the battery drops down to (while cranking till it starts). If it drops below 9 or 8 volts the battery is stuffed.
    3. While its running, you might as well check your alternator charge rate (should be 13 or 14V with no electrical load on).
    4. If you know your battery is still good or have replaced it but keeps going flat, something may be draining it. You can do a current draw test using the AMPS section on your multimeter (switch black lead from COM to AMPS) connect in series to negative battery terminal. From memory a car fitted with a lot of electronics should not have a current draw of more than 80milliamps but it depends on what the factory workshop manual spec is for your car. If its more than what the spec is, start removing fuses one by one to eliminate which part is draining your battery.
    Hope this helps.
  1. Weird Battery Drain
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 16-01-2009, 10:23 AM
  2. blue phosphurous stuff from leaking battery
    Last Post: 21-07-2008, 08:15 PM
  3. Alternator/Charging issues.
    By DoctorDubb in forum Tech and Conversions
    Last Post: 07-03-2008, 05:44 PM
  4. Stock/Standard JZS147 Aristo Battery CCA Rating?
    By Esteban in forum Tech and Conversions
    Last Post: 09-10-2007, 07:40 AM
  5. St18x : Rearmounting the battery
    By Classique71 in forum Tech and Conversions
    Last Post: 07-02-2007, 12:03 AM
