Results 1 to 13 of 13
Thread: indicators not flashing
    Junior Member 1st year Apprentice WeekendWarrior's Avatar
    new south wales
    Default indicators not flashing
    hey guys just wondering, i have an 85 hilux 4x4 2.0ltr and when u turn the indicators on they dont flash they just stay on, now iv replaced the flasher relay but its still doing the same thing hoping someone could shed some light on the subject. and also wondering if someone might have a wiring diagram for this model.
    rob
    - Project "BILLYGOAT" the ta22 found on the edge of a hill
    BEARCON All your construction needs 67 624580
    THE CELICA SHOP COMING SOON
    Default Re: indicators not flashing
    Check all the bulbs to make sure none are blown and they are all the same wattage.
    seeyuzz
    river
    Mar 2008
    inner west syd now!
    popped relay?
    Junior Member Backyard Mechanic KARNAGE's Avatar
    i would be saying its a bulb somewhere in the system, does it do it no matter what side you put them on?
    Apr 2007
    Try playing with your Hazard switch, turn it on & off a few times, it may help ? ..
    Are you sure it was the flasher can for the indicators you changed & not the Hazards flasher can ? ..
    i think its a loose earth, or bung globe
    new south wales
    all the globes are working and when i pulled the flasher out the indicators wouldnt come on at all ans yes it does it to both sides even when u turn the hazards on both sides come on but they dont flash they just stay on
    Metal Guitarist 1st year Apprentice AE35's Avatar
    Check your earths to the indicator assemblies all around.
    1974 Toyota KE25 Corolla | Worked 5K | Twin Dellortos | Extractors | Sports Exhaust | - Memorial Car/Restoration Project/Weekend Car
    1994 Mitsubishi TS Magna | V6 | 5 speed | - Daily Driver
    Dec 2008
    south australia
    sounds like you've got a grounded wire somewhere that is causing the problem
    I'm an atheist but it's not my fault it's the way GOD made me
    Jul 2008
    change the flasher can.
    in case you dont know where it is. under the dash harness area.
    manually make the indicators operate
    youll hear the can click
    gab it ,and feel it click
    remove it, replace it ( take the old one to the autoparts place to match it because some have 2 pin and some have 3 pin units)
    shouldnt be over $15
    Apr 2007
    If you read above, he has already done this ..
    Jul 2008
    apologies i misread he wrote "flasher relay"
    i was looking out for flasher can. sooooooorrrry!
    new south wales
    not a prop buddy thanx for the help guys
  1. TA22 indicators not working
    By joey in forum Tech and Conversions
    Last Post: 30-07-2008, 09:49 PM
  2. Indicators not working :( ...
    Last Post: 09-07-2008, 10:22 AM
  3. "o/d off" Keeps flashing on dash
    By Z2TT in forum Tech and Conversions
    Last Post: 26-05-2008, 09:57 PM
  4. ECU error codes flashing through ABS light??
    By Alchemist in forum Tech and Conversions
    Last Post: 25-06-2006, 08:41 PM
