Results 1 to 6 of 6
Thread: Indicators not working :( ...
    West Australia
    Default Indicators not working :( ...
    Hey all , on my Z20 , i have side indicators on the front bar, not the main ones in front but the side ones , A70's have them aswell
    all my indicators front and rear work , but these side ones on the front bar do not ...
    would it be safe to assume that they are on the same wiring as the fronts / rears ??
    Also another odd thing, is that normally when u have an indicator out the remaining ones flash faster ... this is not happening on my z20 ...
    Any ideas would be great !!
    cheers...
    Default Re: Indicators not working :( ...
    Have you topped up your indicator fluid recently?
    Sorry, i had to.
    Seriously though, make sure all the wiring is hooked up and start checking fuses.
    Junior Member Backyard Mechanic chaRwie's Avatar
    Some indicators use the body as a -negative power source
    maybe ur vinyl has made it lose contact? lol
    Sold: RA28zoku - Bosozoku inspired
    Weekend: JZX100 Mark II - VIP inspired
    New Daily: GX71 Mark II - Bosozoku inspired coming soon...
    Deep Fried Backyard Mechanic ONETEN's Avatar
    yeah the remaining ones flash faster when a bulb in the circuit is out, this is due to the reduction in resistance across the indicatos circuit as one bulb in no longer operating.
    This would definatly point to the bar indicators not being wired in at all. Piggy back them off the nearest indicators, the extra load on the circuit should be fine
    Old School: 1971 Datsun 1200 Deluxe Coupe all original... yep factory twin cam turbo
    Daily: 2006 Hilux Dual Cab D4D 4WD
    Quote Originally Posted by hcope86
    Yes.
    No.
    The resistance increases, and the current drops.
    From http://www.toymods.net/forums/showth...176#post763176
    Quote Originally Posted by Mos
    The flasher is designed to flash fast if it determines that a bulb is blown. The way it determines this is through the current that the bulbs draw. If a bulb blows, the current drawn is lower and the flasher senses this lower current. This is why adding extra indicator lights (such as a trailer) or using the flasher in the hazard mode - where it supplies 6 bulbs instead of 3 - does not result in a different flash rate.
    The most common cause of a lower current draw while still lighting up properly is... LED indicators... Otherwise you need to check that all your bulbs are their correct rating.
    Huh?? Which "This" ?
    Did you check if they are hooked up?
    They should be hooked up to the same circuits, yes.
    Have a look at the thread I linked for a typical diagram of the indicator circuits.
    Chances are you have too many bulbs hooked up. From memory it should be something like 2 x 21W and 1 x 5W - if there's more total wattage than that, even with a bulb out, it won't flash faster.
    Check for everything that's hooked up, checking the wattage of all the bulbs that are flashing. Or keep removing bulbs until it starts flashing faster, though to be honest it's not really a problem that anyone would look for.
    Mos.
    West Australia
    thanks for the help guys,
    i think im just going to cut the wires to the side plugs (which holds the globes) and test with a multimeter if there is even any voltage going down the wires ...
    Ill trace it back to where i can find voltage and maybe splice them into there ...
    Some of you above (excluding mos) musn't have read that the indicators are still flashing at a standard speed, not a faster speed like when you have a globe out ...
    also its not fuses or none of the indicators would be working and/or id have other electrical components not working too
    Cheers all , updates soon ,
  1. hilux self cancelling indicators not working...
    By mc68 in forum Tech and Conversions
    Last Post: 08-09-2009, 12:23 PM
  2. Replies: 7
    Last Post: 02-07-2008, 12:24 AM
  3. How to fix your ST162 tail lights when they stop working
    By mikie_121 in forum Tech and Conversions
    Last Post: 08-04-2008, 04:24 PM
