Different makes of vehicles (holden, ford, mazda, nissan, toyota, etc) have different temperature sensors (ie. they have different resistances and different temperatures). Unfortunately you cant calibrate the microtech to suit your given temperature sensor.
But you have two options.....
1. Re-adjust your cold start enrichment values to suit your given temperature readings.
OR
2. Give John at microtech a call and order a coolant temperature sensor that they sell. I know when I ordered an Intake temp sensor from them it was only like $40 and came with plug and split wiring loom to suit.
I also dont think tapping into the same sensor that you guage on your dash uses is a good idea either as the internal resistance of the guage itself will play a part in an incorrect reading.
I beleive the starlets have another place for a temp sensor that was used by the stock ECU. You could always unwind that out and use a microtech one in its place
Hope that helped.
Dan
