Page 1 of 5 123 ... LastLast
Results 1 to 15 of 73
Thread: RA28 Boltup Brake upgrade ( Crown- corona - ??) WIP
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Thumbs up RA28 Boltup Brake upgrade ( Crown- corona - ??) WIP
    Looking for a Bolt-up solution for my RA28 upgrade - work in progress
    CAR :RA28
    STRUT : XT130 Corona - 3.5inch (88.9mm) caliper spacing
    HUB :MS65 - 5 x 4.5inch (114.3mm) Wheel patten 5 x 100 rotor @ 76mm center
    ROTOR:JZS133 - 280 x 26mm
    CALIPER: still Searching
    Approximate size for Ideal fit, in BOLD are the critical values
    A:36.9mm B:88.9mm 3.5inch C:29mm D:112mm E:72mm 4 Piston @ 43.5mm
    EDIT
    Other options Extracted from postings below, correction made HQ hub changed to VB-VP hub, incorrect info originally obtained.
    HUB :VB-VP - 5 x 120 Wheel patten (rotor is a hub type)
    ROTOR : DBA-015 - 270 x 22mm (with studs & cup)
    CALIPER: S13WB - Hilux V6 4Runner
    Nov 2007
    N.S.W
    Default Re: Crown Hub to Hilux Caliper Clearance
    Caliper Specifications:
    A:=Mounting offSet B:=Mounting holes C:=Rotor GAP D:=Caliper Width E:=Caliper Height
    Hilux S12W A:28.9mm B:88.9mm 3.5inch C:23.3mm D:103mm E:63mm 4 Piston @ 43.5mm weight 5.2Kg each with out pads
    Hilux S13WB A:31.2mm B:88.9mm 3.5inch C:28mm D:112mm E:63mm 4 Piston @ 45.3mm weight 5.7Kg each with out pads
    Hilux 'small' S13W A:31.5mm B:88.9mm 3.5inch C:29mm D:112.5mm E:72.5mm 4 Piston @ 45.3mm
    Jag XJS A:32.5mm B:88.9mm 3.5inch C:27.3mm D:106mm E:77.25mm 4 Piston @ 43.5mm
    Porche 911SC A:30mm B:88.9mm 3.5inch C:23.5mm D:98mm E:70mm 2 Piston
    Mnin AP Racing A:35mm B:88.9mm 3.5inch C:25mm D:145mm E:85mm 4 Piston @ 37mm
    Other Caliper spec Size approximate
    Kelsey Heyes A:30mm B:70mm C:25mm D:96mm E:75mm 4 Piston
    Porsche 944 Turbo A:45mm B:95mm C:27mm D:105mm E:?? 4 Piston
    FC3S RX7 A:30mm B:160mm C:25mm D:100mm E:80mm 4 Piston
    Skyline R33 A:25mm B:100mm C:34mm D:98mm E:80mm 4 Piston
    Fitting the crown MS65 hubs and Hilux calipers to the XT130 strut.
    I found the S12W caliper sit proud of the hubs by 6.5mm.
    Fitted some different wheels and the calipers cleared the wheels no problems.
    Nov 2007
    N.S.W
    Default Re: Crown Hubs to Hilux Caliper S12W & S13W Clearance
    Has anyone looked at using the S13W Toyota surf caliper on a XT130 strut?
    The unit takes a 25mm rotor (Confirmed) @ 270mm (confirmed), these is a much greater overhang at 16mm limiting the wheel choice.
    Would just like to get feedback before going down this path
    Reason: Looking for a bolt-on solution without the need to order blanks rotor which then need machining while keeping the price within reason.
    Nov 2007
    N.S.W
    Found rotor DBA828 is the correct size (but larger centre hole), also needs mounting holes drilled out as the rotor has the thread,
    just waiting to locate a set of calipers & see if it all bolts together.
    EDIT:
    Did some more seaching and found the Crown JZS133 rotor is a direct boltup to the MS65 Hubs, running at Dia 280mm, 26mm thick , 76mm centre hole , 5@100 centre, mounting (10.5mm) holes, also has a set of [email protected] centre mounitng (23mm) holes.
    The Height is 38mm Toyota partnumber 4312-30220/30260/30160.
    Using this rotor rules out the S12W will now search for an other siutable caliper, if anyone know which other calipers use the same spacing as the RA23/28 or XT130/132 this will speed up my seach.
    The S13W will fit but will need a bracket made as a 270mm rotor just fits, the caliper overhang will be 21.5mm
    Nov 2007
    N.S.W
    Default Re: RA28 Boltup Brake upgrade ( Crown- corona - ??) WIP
    May have found a caliper, only problem being due to ear location on strut ideal rotor is 295mm @ 25mm, I’m looking to use a 280mm rotor
    QUESTION: - What is the maximum over/under lap pad to rotor aliment, which wont cause problems?
    I Pity The Grease Monkey the-chief's Avatar
    hahah looks like youv just been talking to yourself
    some may say that this is the first sign of going crazy/ mental breakdown... or menapause
    take your pick
    "All my life, I have searched for a car that feels a certain way.
    Powerful like a gorilla, yet soft and yielding like a Nerf ball. Now, at last, I have found it"
    Celica, The Car Built for Hulky
    I'm listening, I just don't have anything to say. My interest is there though.
    (\__/)
    (")_(")
    Any reason why you don't just use the twin opposing callipers from the corona? Or the 4pot hulix callipers that have been done over and over?
    i guess the best answer to that question is have you tried getting the pug rotors recently??
    I'm listening in on this too as i'm interested in getting a bigger disc. I've noticed that from 91 onwards the ln130 disks were 25mm with 22mm min. This opens up a much larger selection of discs as 20mm thickness isn't very common unless it's euro crap like citroen, pug, renault etc so not easy to get in aus. I've found a few bits n pieces today but gotta investigate more tonight.
    Very helpful site for disc sizes
    https://www.brembo.com/ENG/catalogo_AM/2007/index.html
    you can download the whole catalog (282meg) which i will be doing this evening.
    I've seen somewhere someone using ma61 struts with nissan z31 discs and z32 calipers (modded bracket)
    Could be fun
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Junior Member Grease Monkey amon's Avatar
    NT
    Hey Fellas, i ended up going the XT130 strut,commonwhore rotor and 4 spot hilux all bolts up and i have a million(plethora) of wheel choices from GMH and BMW.With a z20 master and booster braking power is outstanding(especially around Hidden Valley race track).
    Cheers Guy
    What hub did you use amon?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Quote Originally Posted by auto351
    Hundreds before you!
    Corona/Peugeot/Hilux Conversion with Height Adjustable Coilovers
    ([][][]II--LT--II[][][])
    Quote Originally Posted by roadkill
    i always wondered whether the pug disc was something that was going to last a long time or once we exhausted its supply there would need to be a rework.. was the pug it was off a common car?
    Now - RA23-WRX
    Hi.
    i think that the s13w is the one that accomodates the 25mm rotor, and the s12w goes on the 20mm rotor (could be wrong though.....)
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Ah, bugger...
    You're right!
  1. pads for hilux caliper
    By Snyper in forum Tech and Conversions
    Last Post: 12-03-2008, 09:04 AM
  2. hilux caliper comparisons?
    By AE25 in forum Tech and Conversions
    Last Post: 05-12-2005, 07:04 PM
