Results 1 to 11 of 11
Thread: jzz30 1jz mapsensor swap to a 2jz m/sensor??
    May 2007
    victoria
    Default jzz30 1jz mapsensor swap to a 2jz m/sensor??
    Hi all, can anyone tell me if there is any gains to using a 2j mapsensor on a 1j. also would it be harmful to the 1j engine running 2j mapsensor??
    Default Re: jzz30 1jz mapsensor swap to a 2jz m/sensor??
    Have a search in the Tech section.
    Someone compared the two not long ago.
    drunken escapades Conversion King fatboy13's Avatar
    there was no difference in them IIRC... so no point in doing it
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    Xistant
    Guest
    Quote Originally Posted by fatboy13
    as above
    both the same,
    just appearance they are differant.
    May 2007
    victoria
    ok Thanks guys, did a search and found the post on mapsensors.
    i have another question now. what can i replace my map sensor with to over come boost cut without using an aftermarket ecu?
    Have a search for "fuel cut defender"
    Its fuel cut you experience, not boost cut or ignition cut.
    Yep, lots of products available which do what you want. No need to touch the MAP sensor.
    I actually have a spare TRL VFCC if you're interested. No longer need it as I've converted to standalone management.
    May 2007
    victoria
    ok how much posted to melb. its it ready to plug in?
    Also any body used jaycars fuel cut defender if so is it any good?
    Aug 2006
    Have heard ok things bout the jaycar fcd, downside is that you cant set the voltage clamp.
    From memory the jaycar unit clamps voltage at 3.9 v
    May 2007
    victoria
    so is that a bad thing for a 1jz. i would make it run to lean will it?
    Aug 2006
    All depends on what boost you intend to run. The thread on map sensors has a table with boost and associated voltage. Any thing over say 15psi i would want a clamp of 4-4.1 to be safe. As with any fcd or ecu mods its always a good idea to throw it on a dyno and check the afr's.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. 1jz vs 2jz heads
