Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 84
Thread: Motor blown on dyno tune...??
    W.A.
    Default Re: Motor blown on dyno tune...??
    Man it sucks to have a motor blow up on the dyno then obviously not exactly sure why. I'd be shat off too.
    Can i say one thing though, is it not possible that the head gasket simply couldnt hold the boost pressure and has blown for that reason alone? Does it have to be the result of detonation or leaning out or anything else? Sure by the looks of it detonation has been occuring but doesnt neccesarily mean its the reason for the gasket letting go.
    Not trying to cause trouble or stir shit, but just wondering if its just bad luck rather than the fault of the tuner, or yourself for driving it round un tuned.
    Matty
    Junior Member Grease Monkey The GW's Avatar
    Ballarat
    my thoughts exactly guys ok i will post up what i have not much time to write my thoughts:
    tops of pistons
    Second last power run
    AFR for that run
    Manifold Pressure
    Power run of the run BEFORE the black line which is erratic. This shows power SPIKE to 195kw however AFR and boost curve stay relatively consistent and safe?
    I have AFR for all other runs, however i have had it confirmed by a few sources that these are all SAFE and shows him just slowly getting them smoother.
    Manifold pressures look the same for all runs except for the very FIRST run (that he backed out of because of timing) when it made 17 shown below? My manifold is run off an external wastegate with spring setup and no bleedvalve or boost controller just to note.
    Ill post up first run manifold pressure just in case it shows something.
    Havent been able to get into haltech to see what timing is set up for last run, he did tell me and was open about what he supposedly did with timing, he couldve just done an insane run to get a high reading and then changed it back, but has taken it too far?
    I will get timing stuff either.
    please hit me with further opinions and ffedback i really appreciate it.
    rep for all when i get back from training
    1984 SA63 Celica - RIP , 1979 Ford XD - The Lunar Lander
    1972 TA22 Celica - Project Car ,1986 ST162 Celica SX - Gone
    1985 RA65 Celica - Me & ryleys rally car
    1974 TA22 Celica - Current project, 1972 TA22 - Wetish
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Just adding that it wasn't exactly untuned before he took it there, it was running the maps from his old 3T-GTE, and only running a 3 psi spring before we fitted the 17 just before taking it there.
    Jan 2007
    Head gasket has not failed ! There has been blow by past the gasket !
    Block not flat, head not flat, head flexing in that area.
    Ballarat
    what makes you come to that conclusion? im having it tested at the moment, the head anyway
    Jan 2007
    From your pic the seal ring on the gasket is intact !
    So why would you get blow by past an intact seal ring ?
    The seal ring is damaged/miss-shapen by the little dents caused by detonation
    Ballarat
    yes as rod said you can definately see where the detonation has dinted the ring allowing the detonation to reach the material and burn it out...
    Unhappy Re: Motor blown on dyno tune...??
    Couldn't sleep, too hot!
    wa
    Quote Originally Posted by Wildsupra
    Matty
    +000000001
    That may be possible, and its just a coincidence that the worst evidence of detonation is at those two points?
    But also it ran that boost quite happily with a different ecu tuned by a different guy for a few thousand kms. Interestingly though, disregarding the detonation damage, that is the shortest path to the nearest water jackets.
    Forum Sponsor Conversion King
    hmmm having a better look at the gasket i tend to agree with rms (cant zoom in so i could be wrong).
    the dips in the graph are generally due to detonation but the pistons dont seem to show it and the HG is blown in the thinest possible spot.
    any pics of the plugs? also what head studs are you running? how tight? hardness test of the head?
    linden
    PS once na i picked up your bits yesterday so they will be headed back down to you shortly.
    Ballarat
    yeah well it run 16-17 tuned by another guy happily and safely for 6000ks and then i get it tuned at 15psi and it gives way on the dyno? hmm. maybe pistons dont show it as it was so brief the detonation period?ie the dyno runs?
    ill get pics of plugs tomorrow..the cylinders it went in they are clean from the water washing over them
    ok so its either caused by a warped head or block...ill get both checked however both were machined 6000ks ago, we will see though.
    air fuel ratios and boost levels look fine.
    ignition, we dont know? is there any way apart from looking at haltech log of if it were at a dangerous level? and of course he couldve just changed it after the big run that wrecked the motor.
    what couldve caused the spike that is not reflected really in AFR or manifold pressure???
    Tallahassee, FL USofA
    How long since the head was retorqued? Technique?
    All those gasket 'dents' look too symetrical and not on the exposed part of the ring to be caused by detonation to me.
  1. Toymods Dyno Day 16 - Sunday, January 27th
    Last Post: 06-02-2008, 11:03 AM
  2. Toymods Dyno Day 15 - Sunday, July 15th
    Last Post: 24-07-2007, 10:32 AM
  3. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  4. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
  5. dyno tune
    By mideon_696 in forum Tech and Conversions
    Last Post: 06-01-2006, 08:58 PM
