Results 46 to 60 of 66
Thread: Hilux Brake upgrade, BA rotors,billet hubs,R32 calipers (by 289hilux)
  1. #46
    Dreamer Backyard Mechanic millsi's Avatar
    Default Re: Hilux Brake upgrade, BA rotors,billet hubs,R32 calipers (by 289hilux)
    mmm, ive been told several times that either the r32 gtr or r33 gtst calipers work. any way to tell if these are r32 gtr or gtst calipers?
  2. #47
    Quote Originally Posted by WDE_BDY View Post
    Short mounting legs mean GTS-T, demand your money back.
    Callum
    yeah thats what i thought.
    New Zealand
    I should just clarify that, short legs mean R32 GTS-T.
    Callum
  4. #49
    Callum
    yep all over it
  5. #50
    millsi,
    R32 GTSt/Z32 turbo - have the ribs as you have shown (beware that there the Z32 NA had 22mm wide discs as opposed to 30mm of the turbos)
    R32 GT-R (non-V spec) - easiest way to identify are the little half moons at the bottom (made for a 32mm disc but have been used successfully with BA 28mm rotors)
    R33 GTS - smooth all over
    And here are the discs available for comparison
    One thing to note which can cause issues is the R34 GTT uses a 310mm disc and the caliper is the same as the R33 GTST but with longer legs to suit.
  6. #51
    cheers big zop
  7. #52
    guy still seems to think that they are 32 gtr calipers.
  8. #53
    New Zealand
    Got a Skyline you can try them on? All the hub mounts are the same so it will soon show what size disc it is designed to fit. I know Sheepers has some on his RA28 with the proper disc, see if he can get comparative pictures for you.
    Callum
  9. #54
    Quote Originally Posted by millsi View Post
    The calipers with the fins are r32 gtst as explained very clearly by BIGZOP above.
  10. #55
    Sep 2008
    can someone measure the bolt spacing on the lux/skyline calipers as id like to see if i can do this conversion on my hiace and the nearest pick a part is an hour away from me.
    and also the measurement from the calliper mounting surface (on the spindle) to the rotor/wheel mounting face on the hub
    thanks
  11. #56
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    well it seems MR spares has wise up and now trying to flog off a " TOYOTA HILUX ADAPTOR R32 HUBS AND ROTORS" package............................. and the price he wants is $600. What a fucking joke that is
    Price does not even include that calipers lol
  12. #57
    Nov 2008
    queensland
    and now i find out he's after $350 just for the hubs
    Not so much of a "cheap" conversion now
  13. #58
    V8 motavation. Grease Monkey 289hilux's Avatar
    Oct 2007
    If you want to do it cheap. Just remove the rotor from the Hilux hub and use wheel spacers.
    I have had my billet hubs for three years now and the price has not changed that much. If you go back the the start of this thread you can check my original costings.
    The way I see it is you get what you pay for. Don't hold it against Mr Spares he has a business to run.
    As far as I am concerned it is a cheap conversion.
    Have you checked the price fro others like Hoppers Stoppers.
    There set up will set you back $1200.
    Cheers.
    Injected 5.0L FORD power in HILUX is the only way forward!
    See my ride here: http://www.toymods.org.au/forums/sho...246#post601246
  14. #59
    Will this setup work on a RN41 Hilux with twin spot sumitomos and what size wheels will I need.
    Philip
  15. #60
    KiwiCruzn Grease Monkey supra7m8u@yahoo.com.au's Avatar
    new south wales
    can you help me out this is all new to me. My enginners whats me to upgrade my brakes i am in sydney . please help need to upgrade to bigger brakes and dont know how to go about it
  1. Basic Steering Wheel Conversion
    By Andrew162 in forum Tech and Conversions
    Last Post: 23-11-2006, 09:43 PM
  2. AE86 hand hits indecator!! momo wheel
    By Adrogen in forum Tech and Conversions
    Last Post: 10-06-2006, 06:09 PM
  3. st162 wheel bearing/stub axle
    By BeRad in forum Tech and Conversions
    Last Post: 15-10-2005, 08:29 AM
  4. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
