Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: DIY: Pajero brake master cylinder upgrade
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Default DIY: Pajero brake master cylinder upgrade
    I finally got around to upgrading the brakes on my AE71 with a simple bolt in RT132 Corona twin pot setup. I found that a common and simple upgrade for the master cylinder was the pajero type which is about 15/16 in size. This size of MC is sufficient for most brake upgrades like hilux & rx7 4pots etc.
    This upgrade is suitable to corollas such as KE35/TA22/AE86/TE72/AE71.... well pretty much anything with an 80mm bolt spacing on the brake booster. Pics will explain it.
    Original ae71 MC:
    Pajero MC:
    This shape of Pajero 1986-87:
    To add further: The Brake MC can be found in the following Pajero's and Triton's.
    Pajero
    NB, NC 2.3lt, all fuel types, LWB 11/84 - 10/86
    ND turbo 2.5lt diesel 10/87 - 07/88
    ND 2.6lt LWB 10/87 - 08/88
    NE SWB 10/87 - 08/88
    Triton
    ME 4X4 10/86 - 07/88
    MF 4X4, 4X2 07/88 - 09/89
    Default Re: DIY: Pajero brake master cylinder upgrade
    Another thing which isnt mentioned in the forums is that the pajero MC has a banjo fitting for the front brake port. The banjo fitting is actually a double adaptor for two brake lines, This is useless as the corolla has just a front port and a rear port. Simple solution was to find a banjo fitting to suit a single brake line.
    A fitting of this sort seemed to be a bit pricey. Luckily i found what car to find them on whilst parts hunting at pick n pay.
    1989 GD Ford Telstar:
    Single Telstar banjo fitting:
    Double Pajero banjo fitting:
    New banjo fitting assembled on pajero MC in my AE71:
    Hoppers Crossing
    nice work. did this a long time ago in my ta22, always wondered what shape of mitsu it came out of.
    Good work on finding a banjo fitting from another car. They do get expensive.
    Yeah especially when you got to get them custom made i.e. motorsport connections, pirtek, enzed, etc.
    +rep to u for locating a banjo, i had to go all over town to find one and was lucky some ol'mate in a workshop had one in his tool kit.
    They also come out of Mitsu Starions. I had always wondered what else used the same master....
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Thank you Kebin. I'll take advantage of this info in the near future!
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    No worries fellas,
    Those single banjos can also be found on the clutch master of the gd telstars... manual models obviously. So theres plenty out there anyway
    Junior Member Domestic Engineer TA22 GT's Avatar
    Nice work, does the Pajero M/C have a low level switch or does a cap from something else fit that has one?
    I want to do this upgrade on my TA22 but I prefer the low level switch so the OK monitor keeps the right signal.
    Simon
    im pretty sure it does, but i'd have to double check this weekend
    You mean like a float/switch for the brake warning light?
    yeah it does
    what pajero is that year/model?
    google.com is your friend
    but if you like
    from 5 min redbook and carsales research i know that pictured pajero is nd model, 10/86-1987. but maybe from before and after that year is the same or compatible probably
    By The Witzl in forum FAQ
    Last Post: 12-02-2018, 12:26 PM
  2. TA22 Brake Master Cylinder options...
    Last Post: 09-11-2017, 12:14 AM
  3. Replies: 1
    Last Post: 28-04-2011, 11:45 PM
  4. Replies: 3
    Last Post: 06-07-2006, 06:11 PM
