Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
Thread: xJZ-Series Engine Variants
    Default xJZ-Series Engine Variants
    Engine model and generation:
    1jz-gte non VVTI
    Top End Modifications:
    none
    Bottom end modifications:
    none
    Forced induction:
    HKS TA45s, .9 turbine a/r, .72 comp a/r, 62mm comp inducer, 56 trim. On Trust exhaust mani with Trust 50mm gate. 17psi used for dyno.
    Management:
    Microtech LT12s and x6 igniter, stock coils.
    Fuel used:
    Shell V-power racing plus Martini Super Boost
    Intake:
    4" K&N pod
    Exhaust:
    4" dump pipe, 3" cat, 3" exhaust, 3" straight through muffler.
    Driveline:
    shift kitted a3041LE, 8" pajero diff.
    Other info:
    Chinese FMIC, 3" cooler piping, 550cc injectors, 040 fuel pump.
    QUICKEST 1JZ'S IN OZ
    Default Re: xJZ-Series Engine Variants
    1jz-gte non VVTI
    none
    none
    Forced induction:
    Garrett GT3076R, .82 turbine a/r, .7 comp a/r. 6 into 1 stainless 50mm runners manifold with tial 44mm gate. 23psi used for dyno.
    Management:
    Power FC with FC datalogit. Stock ignitor with HKS type-dli piggy backed, stock coils, suprastick V4 transmission management, Blitz SBC ID3 boost controller.
    Fuel used:
    Intake:
    4" DNA motorsport stainless steel mesh pod
    Exhaust:
    3.5" dump pipe, 3" exhaust, 3" cat, into 2x 2.5" exhausts with 2x2 mufflers.
    Driveline:
    Col Voss rebuilt and upgraded a340e auto, MV autos 3200rpm stall converter, Supra 4.11 torsen diff.
    Other info:
    DNA motorsport FMIC, 3" cooler piping, 650cc injectors, walbro fuel pump.
    1/4 mile:
    [email protected]. Weight with driver of 1720kg.
    Toyota Corolla Conquest 2003 black manual 1ZZ-FE - Daily
    Toyota Soarer GT-TL 1991 white auto 1JZ-GTE - [email protected] 1.587 60'
    My JZZ30 SOARER
    Junior Member Backyard Mechanic 1983supra's Avatar
    2jzge NA non VVTI
    none
    none
    Forced induction:
    none
    Management:
    Chiptorque Xede piggy back ECU
    Fuel used:
    BP Ultimate
    Intake:
    HKS Pod filter, carbon fibre air box and ducted cold air intake
    Exhaust:
    2.5" exhaust system from custom ceramic coated extractors
    4" high flow Cat and straight thru muffler
    Driveline:
    JZA80 W58 5 speed gearbox
    Lightweight custom billet flywheel (1kg lighter than stock)
    Heavy duty Xtreme clutch
    True Trac limited slip diff
    Car:
    1989 Cressida GLX
    1JZ-GTE non VVTI (JZX81 Chaser)
    Greddy adjustable exhaust cam gear (if that counts) on 6 degrees retard, JZA70 throttle body, internally polished factory turbo piping, restrictive factory hoses replaced with silicon units, stock cams
    none
    Forced induction:
    eBay "China" CT12A steel wheel turbos (copies of the factory ones). 18psi boost, Blitz Dual SBC electronic boost controller
    Just Jap cheapie 600x300x75 intercooler, 2.5" cooler piping
    Turbosmart Dual Port BOV (factory one leaks - removed)
    Management:
    Stock ECU with HKS FCD trimmed to 4 volts (setting 8). Stock ignitor with stock coils (cracks PVC glued), NGK BKR6EIX iridium spark plugs.
    Fuel used:
    Shell V-Power (Optimax) 98 octane + 1 bottle of 'pro strength' octane booster
    Intake:
    3" intake pipe with simota pod filter (located in guard for cool air supply instead of engine bay), ram air intake
    Exhaust:
    Twin 2.5" dump pipes going down to 3" highflow cat, 3" exhaust to offset oval muffler, no rear cannon
    Driveline:
    JZX81 Chaser A341LE auto, MV autos Stage 1 shift kit, Grande LSD 3.9, standard tailshaft, standard torque converter, line pressure/kickdown cable tightened
    Other info:
    Walbro 255lph in-tank fuel pump, stock injectors (duty cycle unknown).
    1/4 mile:
    12.368 @ 111.31mph, 1.86 60 foot on Falken Azenis RT615 tyres
    1500kg on the dot, with half a tank of fuel and no driver (68kg). AC removed.
    http://homepage.mac.com/rib_feast/cr...dyno_328hp.wmv
    http://homepage.mac.com/rib_feast/cressida_12.3.jpg
    http://homepage.mac.com/rib_feast/cressida_12.3.wmv
    Stock cam gear setting vs 2, 4, and 6 degrees retard, showing torque:
    Stock cam gear setting vs 6 degrees retard:
    Stock cam gear setting vs 2, 4, and 6 degrees retard, showing AFRs:
    http://homepage.mac.com/rib_feast/cr...e_bay_blue.jpg
    244rwkw / 328hp @ 18psi
    Junior Member Automotive Encyclopaedia big JON's Avatar
    May 2006
    1JZ GTE non VVTi
    nil
    nil
    Forced induction:
    GReddy T67-25g, GReddy stainless steel manifold, GReddy 50 external wastegate. 16psi high boost, 11psi low boost
    Management:
    Apexi SAFC, Apexi AVCR, standard computer (obviously )
    Fuel used
    BP Ultimate, 98RON
    Intake:
    HKS Mushroom style filter, custom alloy neck to turbo
    Exhaust:
    Custom 3.5" off turbo, standard cat, 3" after cat into HKS Super Dragger cannon. Screamer pipe off wastegate line
    Driveline:
    Some type of button/puk clutch (unknown, fron Japan), Torsen 4.1 lsd
    Other info
    Trust front mount with custom piping
    **going on the dyno again tomorrow. Final tune (above) was done on Dyno Dynamics, tomorrow is Mainline DynoLog so will be interesting to see the difference
    236 rwkw
    (I'll post the dyno graph as soon as I can find it)
    2JZ-GTE non-VVTi
    None
    None
    Forced induction:
    Stock twin CT20A turbos, approx 18psi
    Management:
    Stock
    Fuel used
    BP Ultimate 98
    Intake:
    Stock
    Exhaust:
    Custom dual dump pipe, full 3" system
    Driveline:
    W58 5-speed manual
    1JZGTE VVTi from JZX100 Chaser, in 2000 model IS200
    None
    None
    Forced induction:
    HKS GT3040 with 1.12 rear on modified standard manifold
    Management:
    Motec M600
    Apexi AVCR
    650cc injectors
    Fuel used:
    Caltex Vortex 98
    Intake:
    Pod filter
    Exhaust:
    3" turbo back mandrel with genuine metalcat
    Driveline:
    R154 5speed, stock IS200 diff, heavy duty exedy button clutch
    Junior Member Backyard Mechanic gwilmarlio's Avatar
    1JZ-GTE non-VVTi JZA70 R
    none
    none
    Forced induction:
    Stock twin ct12a
    Management:
    Apexi Power FC
    Fuel used
    BP 98
    Intake:
    HKS mushroom pod
    Exhaust:
    3" custom dump into 3" test pipe then 3" Fujitsubo Jasma stainless with 2 mufflers
    Driveline:
    R152 5speed
    stock clutch
    4.1 torsen rear end
    1990 JZA70 R 12.959sec at 112.78 mph Kwinana Motorplex
    1J torsen smashing machine
    TR44 Highflow single (366whp at 17psi)
    1988 GA70 SOLD and will be missed
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    1JZ-GTE 91
    nil
    nil
    Forced induction:
    factory ct12a's
    Management:
    stock
    Fuel used
    98
    Intake:
    K&N pod, Cold air feed, stock JZA70 intercooler
    Exhaust:
    3" from stock dumps to tip incorperating cat, 2 mufflers, super turbo resonator and a genie exhausts oval tip
    Driveline:
    A342E with redline D4 ATF, torsen LSD with redline superlight shockproof
    Power at the wheels.
    326 rwhp / 243 rwkw @ 18 psi / 1.2 bar.
    1JZGTE / JZA70.
    None.
    None.
    Forced induction:
    Standard factory twin turbo. (CT12A) x2.
    Management:
    A'PEXi Power FC - A.P Engineering Pro.
    Fuel used
    BP Ultimate 98.
    Intake:
    A'PEXi pod filter, ARC intercooler & LF Performance custom cold air induction/intake system.
    Exhaust:
    Butler Built twin dump pipes, modified Blitz NUR Spec catless exhaust.
    Driveline:
    Standard factory R154 & Torsen 4.1:1.
    PB 1/4 Mile:
    In signature...
    JZA70|R / 12.45 @ 111 mph.
    pic to follow, 210rwkw
    1jz-gte non VVTi
    none
    none
    Forced induction:
    stock ceramic twins 15psi used for dyno.
    Management:
    stock, FCD
    Fuel used:
    98 octane of some description
    Intake:
    4" K&N pod
    Exhaust:
    twin 2.5" dump pipes, 3" cat, 3" exhaust, 3" straight through muffler.
    Driveline:
    A341LE,
    Other info:
    Stock FMIC,
    this was before cooler, or stallie,
    The boobs are back
    2JZGTE
    Link to chart: 476rwhp
    Car:
    R31 Skyline. Take that RB fans!
    US Spec intake cam
    Ryco oil filter
    Forced induction:
    GT35R XR6 spec, ported internal gate with bigger arm and flap, 1.06 rear. 0.5 front, extra springs on the actuator. Apexi AVCR boost controler.
    Management:
    Stock + SAFC
    Fuel used
    Boost 98
    Fuel system
    Intank mounted Bosch 044, stock fuel lines. 550cc injectors.
    Intake:
    K&N pod. Stainless pipework. Ebay 600x300x100mm FMIC. Traction control cut out of the throttle body.
    Exhaust:
    3.5" Dump pipe. 3.1" truck exhaust with one straight through muff and ebay cat.
    Driveline:
    A340E trans with MV stage 1.5 shift kit and 2800rpm stallie.
    Vids:
    http://www.youtube.com/watch?v=f2YqeVZ5MbM
    http://www.youtube.com/watch?v=dEzrLHqe-JA
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    325rwhp @ 18psi.
    Car:
    Toyota Soarer GZ20
    1JZ-GTE JZA70 Non VVTI.
    none
    none
    Forced induction:
    Ebay T70 Turbo, Ebay Manifold, Pod-On-Turbo Hot Air Induction. 48mm Wastegate.
    Management:
    Wolf 3D
    Fuel used:
    Optimax 98
    Intake:
    4" K&N pod-on-turbo-hot-air-induction
    Exhaust:
    Full 3" Trust Exhaust System.
    Driveline:
    JZA70 Box, TRD 2Way LSD
    Other info:
    600x300x70 FMIC, 2 Fuel Pumps, Wasted Spark Ignition Sytem.
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
    Spent this afternoon on the dyno with the panelvan, ended up being more of a familiarisation session with the Microtech (i'm used to tuning with laptop controlled Haltech). Turns out the manual boost controller I have is shite, being ok for adjustments up to about 12 psi, but anything over that has a massive boost spike, as bad as 11psi over the target! Needless to say tuning with this problem was like a dog chasing its tail, so the current state of tune is pretty ordinary.
    Some indicative figures were measured, apologies though as I don't have the dyno sheets for them, will get some after the next session :-)
    8psi 191rwkw
    10psi 210rwkw
    15psi 248rwkw
    ~20psi 278rwkw *this was at only 5000rpm, as the boost tapered back sharply to 14psi at higher revs
    1jz-gte non VVTI
    none
    none
    Forced induction:
    Garrett GT30 (500hp), .82 turbine a/r, .70 comp a/r, factory twin manifolds with 2.25" Y-pipe, HKS copy 40mm wastegate with 8psi spring + manual boost controller
    Management:
    Fuel used:
    Shell V-power 98 octane
    Intake:
    4" K&N pod
    Exhaust:
    3" dump pipe & exhaust with 2 mufflers, wastegate exit plumbed back into exhaust.
    Driveline:
    MV Automatics stage 1.5 shift kitted A3040LE, 2800rpm stall, 7.5" corona diff.
    Other info:
    600x300x76mm FMIC, 2.5" cooler piping, 540cc injectors, 040 fuel pump, PK20R8 plugs at 0.8mm.
    1jz-gte non VVTI
    none
    none
    Forced induction:
    Hypergear TR44 (57mm comp wheel, .63 turbine a/r) Similar to Garret GT3076R but not ball bearing. 15psi boost.
    Management:
    Microtech LT12s and x6 igniter, stock coils with glued up cracks. Greddy Profec B II EBC.
    Fuel used:
    Intake:
    3" no name filter
    Exhaust:
    3" dump pipe, decat, 3" pipe.
    Driveline:
    shift kitted a3041LE, Hilux diff 4.11.
    Other info:
    Chinese FMIC, 3" cooler piping, 550cc injectors, 044 fuel pump. 50hp N2O used. 11.8AFR's on non nitrous run and 11.0's used on nitrous run.
    No NOS
    http://www.youtube.com/watch?v=-5QfzvgqTuo
    NOS
    http://www.youtube.com/watch?v=Irga3KD7cp0
  1. sticky dyno results thread
    By chris davey in forum Toymods Car Club Membership and Feedback
    Last Post: 20-06-2007, 07:07 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Final Results!
    Last Post: 24-02-2006, 12:12 AM
  4. Dyno Day 12 - results thus far...
    Last Post: 28-01-2006, 01:35 PM
  5. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
