Results 31 to 45 of 61
Thread: xJZ-Series Engine Variants
    Forum Sponsor Conversion King
    Default Re: xJZ-Series Engine Variants
    Engine model and generation:
    1jz-gte non VVTI
    Top End Modifications:
    none
    Bottom end modifications:
    none
    Forced induction:
    HKS TO4S, .84 turbine a/r, .60 comp a/r. Junky Y pipe with HKS 38mm gate. 16psi used for dyno (couldn't be arsed changing wastegate spring or building a proper manifold)
    Management:
    EMS Stinger V4, stock igniter, stock coils.
    Fuel used:
    Caltex vortex
    Intake:
    4" K&N pod on a pipe
    Exhaust:
    3" dump and exhaust, 3" straight through muffler.
    Driveline:
    a340, 8" hilux diff.
    Other info:
    Chinese FMIC, 2-2.5" cooler piping, 440cc injectors, 044 fuel pump.
    run was done on DD16 but due to it being a 3rd run i wasn't entitled to KiloWattKing
    meh, most improved by 2422% was good enough
    1jz-gte non VVTI
    none
    none
    Forced induction:
    Hypergear TR44 (57mm comp wheel, .63 turbine a/r) Similar to Garret GT3076R but not ball bearing. 15psi boost with 50shot, 19.5psi and 19.5psi with 50 shot.
    Management:
    Microtech LT12s and x6 igniter, stock coils with glued up cracks. BCPR7E plugs gapped to .6mm. Greddy Profec B II EBC.
    Fuel used:
    BP Ultimate with 30% Toluene mix
    Intake:
    3" no name filter
    Exhaust:
    3" dump pipe
    Driveline:
    shift kitted a3041LE, Hilux diff 4.11.
    Other info:
    Chinese FMIC, 3" cooler piping, 550cc injectors, 044 fuel pump.
    QUICKEST 1JZ'S IN OZ
    May 2007
    1JZ-GTE non-VVTi (1991)
    Stock
    Stock
    Forced induction:
    Stock twin turbos (12psi)
    Management:
    Apexi V-AFC
    Fuel used:
    BP Ultimate
    Intake:
    Trust FMIC with generic pod
    Exhaust:
    3" front pipe back
    Driveline:
    Stock R154
    Aristo 2JZ-GTE non-VVTi
    HKS 272 cams, mild porting, 80 lb/in valve springs
    none
    Forced induction:
    Garrett GT35R, 1.06 turbine a/r, .70 comp a/r. Chinese SS manifold with HKS 38mm gate. 15psi boost pressure.
    Management:
    Haltech E6K, MSD DIS4, stock coils.
    Fuel used:
    BP Ultimate
    Intake:
    None (removed air filter)
    Exhaust:
    3" dump and exhaust, 3" cat and straight through muffler.
    Driveline:
    V160 6-speed, stock diff with 3.58:1 gears
    Other info:
    Chinese 100mm FMIC, 2.5" cooler piping, Sard top-feed dual-entry fuel rail, 700cc injectors, Sard fuel pressure regulator, dual Walbro 255lph pumps.
    1JZGTE non VVTi version
    none
    none
    Forced induction:
    standard ct12a twins
    Management:
    Apexi PowerFC
    stock injectors
    Fuel used:
    BP Ultimate 98 octane
    Intake:
    3" alloy pipe w/ knN panel filter
    Exhaust:
    stock y pipe
    3" from there with big muffler and metal cat
    Driveline:
    R154
    Other info:
    Boost controller on roughy 16psi. Boost leaks at peak power to 14.*psi...
    Jase
    JZA023
    2JZ-GE Non-VVTi
    none
    none
    Forced induction:
    N/A
    Management:
    Stock ECU + Chiptorque Xede Piggyback(Timing & A/Fs)
    Fuel used:
    BP Ultimate(98RON)
    Intake:
    3" HKS Mushroom
    Exhaust:
    HKS Kainsai Extractors, High Flow Cat, 2 1/4" cat back exhaust
    Driveline:
    V161 6 Spd Getrag, Torsen LSD
    Other info:
    Custom heatshield & heat wrapped extractors
    User Conversion King
    NWA
    2JZ-GTE non vvti, ex aristo
    none
    none
    Forced induction:
    standard CT20 things. i converted the rear 'prespool valve' to a wastegate. the dyno run above was done in parallel mode. it made less in sequential. it was running ~17.8psi in the dyno run above
    Management:
    standard ECU etc. homemade fuel cut defender
    Fuel used
    98octane BP stuff
    Intake:
    pod filter, 600*300*76
    Exhaust:
    straight through 3", no restrictions
    Driveline:
    standard auto, 4.1:1, MA61 LSD
    hello
  8. #38
    Jun 2008
    Toyota Soarer JZZ30
    1.5jz non vvti
    1j head, Ported and Polished with BR Springs, Ti Retainers, 2jz Intake Valves
    Built, Balanced and Blue Printed
    Forced induction:
    Garrett T04z
    Management:
    Microtech LT12s, x6 with Bosch coils, running 1.1mm gap, 800cc inj.....
    Fuel used:
    BP Ultimate(98RON) no booster
    Intake:
    4" intake, 600 x 300 x 100 FMIC, 83mm TB, Custom Plenum
    Exhaust:
    Custom 4" system
    Driveline:
    Built a340e, Manualised with CAM's Shift Box, CAM's Shift Kit, Torsen LSD
    Other info:
    It made 357rwkw / 478rwhp @ 6000rpm this is where the current fuel system maxed out.
    Fuel system has just been upgraded with twin Walbro GSS342hp pumps and will soon be getting rev limiter raised to 7800rpm. Then back to the dyno
    Current Builds
    Soarer Built 1.5jz 425rwkws
    1JZ LPG Build, so far 204rwkw@10psi
  9. #39
    Dec 2008
    2jz-gte non VVTI
    HKS 272 cams, performance valve springs and retainers
    none
    Forced induction:
    HKS T51R KAI non bb kit HKS 60mm gate and hks manifold
    Management:
    HKS F CON V un tuned with T51r fitted
    Fuel used:
    Shell V-power
    Intake:
    4" K&N pod
    Exhaust:
    3" dump pipe, 3" cat, 3.5"Jazma exhaust,.
    Driveline:
    V160,excedy twin plate
    Other info:
    105mm ARE FMIC, 3" cooler piping, standard 440cc injectors, 044 fuel pump.
    Power Made:
    423.8 kw on 21psi
    __________________
  10. #40
    Interesting back-to-back comparison on the weekend at the Toyota Nationals in Dubbo, did one run with converter locked (A340 auto box), then unlocked. You can see the benefit of the torque multiplication at lower revs, but then also how far behind it falls with converter slip once 120kph road speed is reached:
  11. #41
    Junior Member Backyard Mechanic gwilmarlio's Avatar
    Well Time for an update
    1JZ-GTE non-VVTi JZA70 R
    none
    none
    Forced induction:
    TR44 High Flow (hypergear)
    Management:
    Stock ECU
    Fuel used
    BP 98
    Intake:
    K&N Filter HKS pipe
    Exhaust:
    3" custom dump into 3" test pipe then 3" Fujitsubo Jasma stainless with 2 mufflers
    Driveline:
    R152 5speed
    Xtreame 6 puck single puck
    4.11 torsen rear end
    1990 JZA70 R 12.959sec at 112.78 mph Kwinana Motorplex
    1J torsen smashing machine
    TR44 Highflow single (366whp at 17psi)
    1988 GA70 SOLD and will be missed
  12. #42
    I to should update, though i dont have a dyno scan with me...
    401.8 whp @ 17psi
    none
    none
    Forced induction:
    Garret GT3582r, 6boost manifold, turbosmart 50mm progate ewg
    Management:
    Apexi Power FC
    Fuel used
    BP 98
    Intake:
    none
    Exhaust:
    3" custom dump into 3" side pipe, metal cat and huge mufler (brand?)
    Driveline:
    R154 5speed
    OS Gilken 650hp twin plate
    JZA023
  13. #43
    Jun 2008
    Update
    Last time I was on the rollers she ran out of fuel at 357rwkw at 5800rpm. Since then the fuel system was changed to twin Walbro 342
    Here is the current setup
    Toyota Soarer JZZ30
    1.5jz non vvti
    Forced induction:
    Garrett T04z
    Management:
    Fuel used:
    Intake:
    Exhaust:
    Custom 4" system
    Driveline:
    R154, Jim, Berry Carbotic Clutch, Torsen LSD
    Fuel system:
    Current Builds
  14. #44
    Toyota Farmer Grease Monkey Yotaholic's Avatar
    Feb 2007
    NFLD.
    1jz-gte gen 2 non VVTI
    USDM 2J cams / Titan Adj cam gears
    none
    Forced induction:
    HKS T3G kit
    Management:
    Emanage Ultimate / Mines ECU/ XS controller
    Fuel used:
    94 oct/ Meth injection
    Intake:
    3" AEM dryflow
    Exhaust:
    HKS manifolds, HKS y pipe / 3" SS / no cat / one resonator/ Magnaflow 14815 muffler
    Driveline:
    R154
    Other info:
    Need a bigger IC
    82 Ma61 1JZ/R154 HKS Twins
    94 JZA80 V160 S475R (sold)
    94 JZA80 V160 T51R KAI CDN. Spec
  15. #45
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    Car: MX73 cressida
    1jz non vvti
    hks 264 deg cams with fedanza cam gears
    stock
    Forced induction:
    gt35r .82 rear housing custom steam pipe manifold
    Management:
    Microtech LTx12s, Bosch coils MSD leads, 800cc inj..... apexi avcr boost controller
    Fuel used:
    BP Ultimate(98RON)
    Intake:
    4in pod front mount with 3in piping standard plenum
    Exhaust:
    3in turbo back (cat forward is stainless waiting to come back form darwin to finish it off)
    Driveline:
    R154 custom 5puck clutch (rated to 600rwhp) one piece tail shaft, true track with 4.11 diff gears
    Fuel system:
    Walbro 550 in tank going into a bosh 910 motor sports running 1/2 inch alloy fuel line malpassi fuel pressure reg feeding into both sides of the standard fuel rail
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
  1. sticky dyno results thread
    By chris davey in forum Toymods Car Club Membership and Feedback
    Last Post: 20-06-2007, 06:07 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  3. Dyno Day 12 - Final Results!
    Last Post: 23-02-2006, 11:12 PM
  4. Dyno Day 12 - results thus far...
    Last Post: 28-01-2006, 12:35 PM
  5. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
