Results 1 to 15 of 23
Thread: strength of the steel case 5 speed?
    Default strength of the steel case 5 speed?
    does anyone know how tough the steel case box in the ra23 is? ill be using it behind a highish powered 4g63 2litre. I just need to know before i order the bell housing from dellow.
    It bolts the narrow block mitsubishi engine straight up. Is the steel case the same pattern as a supra or other box so i can still use the new bell housing if i blow the steel case 5 speed?
    Default Re: strength of the steel case 5 speed?
    if its a dellow i think the biggest problem will be the bolt holes not lining up...
    disclaimer: this is all heresay, but ive heard alot of people say...
    and if it does all line up. then drive it gently and you'll be right. kick the clutch too much with sticky tyres and you'll be in trouble.
    i think you would get away with it for a while
    Montrose
    Why not use a better box to start with?? And a better bellhousing!
    Steel case celica box known as the W50?
    Id suggest going a w55/7/8 and never look back.
    Aug 2006
    at $100 a box who cares how much power it can handle, but if you want reliablity i would go somthing better.
    how much do the better boxes cost, and do they bolt into an ra23? if i buy the bell housing now will it also fit the other boxes? thanks.
    I expect to get running 10 or 11 sec 1/4s too
    Montrose
    Better boxes will cost from $50-$1000, depending where you buy one. Different bolt pattern on the bellhousing. They are known as the 'supra box' to places like Dellow and CRS. 10 second quarters on a W50 = much munching of bits.
    thanks mate, so what do i look for, and where do u suggest. ill need one now as ill need to buy the bellhousing for it anyway before i can start mounting the engine. wat mods are needed for an ra23
    The w58 come in ra60/65s. other types not sure.
    so they are referred to as a supra box when they arent from a supra? will they last for what ill be needing it for
    Montrose
    they come from a bunch of different cars, but most commonly NA supras and Celicas.
    the W55, W57 and W58 are all tough boxes.
    http://www.club4ag.com/faq%20and%20t...Dgearboxes.htm
    theres a little comparo on the boxes you might like to choose.
    thanks this is all very helpful. is it easy to get parts to rebuild a w55,7,8?
    any ideas how to fit the ra23?
    theyll fit fine into a 23. fit into a stock ke70 tunnel...
    Montrose
    Parts for these boxes are fine. Fitting it should be about as easy as any box can be to fit.
