Results 1 to 15 of 28
Thread: Engine Stopped while running! Help!! 22R
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Default Engine Stopped while running! Help!! 22R
    For those that havent seen it.
    Quote Originally Posted by Herus
    Well i was on my way home Wednesday Night, left work late as was working back trying to catch up on some stuff. Started the car, got out of work and 100m down the rd.
    Suddenly nothing.
    Battery light was on, as tho the car had stalled.
    Swore, hit the key, clink.
    tried again
    clink.
    hit the hazards, got out, checked the battery, all good. tried again. clink.
    pushed it to the side of the rd, went to the ford dealership across the rd, tried a jump start pack.
    Clink.
    Pushed it into the dealership, called the RAA. They asked if the ford guys had worked on it. I nearly laughed.. Im not letting ford techs near my car
    The RAA Guy got a ring spanner onto the main bolt in the engine and couldnt turn it. Not even 1mm.
    tried the car in 4th gear and rocked it. nothing.
    Tow truck home for me.
    Moving on from there, i decided to pull the main covers off to see what i could find.
    Removed the Rocker Cover, and found nothing looking to shabby.
    Removed the Sump (2 hours of swearing later) and still nothing looking bad!!
    I was wondering if anyone who knows slightly more about engines could have a look, and let me know what they think about it.
    Pics are Here
    I figured it best to leave it in high res, so that you can zoom and have a better look.
    Thanks guys
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Montrose
    Default Re: Engine Stopped while running! Help!! 22R
    So... no big clunky noises when it died?
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    put the engine on a stand and pull the main bearing caps off and have a look see
    I'm not sure if u can take off to inspect while still in the car hopefully someone else can answer that
    has the motor seized? have you tried turning the motor over by using the large bolt on the harmonic balancer? try using the process of elimination before you strip the motor down.
    If you can rotate the crank by using the harmonic balancer bolt, (not seized)
    Try this and then let me know the results
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Feb 2007
    Quote Originally Posted by airfireman1
    Tried it
    Nothing, cant move it.
    Quote Originally Posted by mrshin
    Nope, nothing, ive had so many people asking me this question! there was nothing... i had just dropped back to second doing about 30-40km/hr, and it died...
    Quote Originally Posted by gearb0x
    I dont have a lift or a stand
    Thanks
    Andrew
    Is the car a manual? When the engine died did it lock up the rear end?
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    Feb 2007
    Nah nothing unusual, was just like it stalled.
    Can still roll the car in neutral, all the gear selectors are fine, starter motor isnt jammed, removed the plugs and its not full of water.
    there was no bangs, rattles, unusual noises, etc coming from the car when it died.
    It was exactly like it had stalled.
    Andrew
    I'm assuming that when it stalled/stopped running you were in gear. So assuming you were in gear did it keep rolling or like mentioned above did it lock up the rear end?
    So far it sounds like a seized motor
    - LeeRoy
    Feb 2007
    was still rolling.
    Seized motor is about what im getting the impression from with everyone i talk to.
    Oil level was low, but not extremely bad, was really nothing unusual going on.
    where would it seize?
    thanks
    Andrew
    Bearings would seize if they weren't getting enough oil.
    seeyuzz
    river
    Feb 2007
    Surely there would be some kind of noise then though?
    It was running quiet with no hassles
    Andrew
    wa
    my money would be on snapped timing chain bunched up at bottom of timing cover
    pull off the rocker cover and see if the chain is still on your cam gear
    Feb 2007
    If you check the pics, the timing chain is sitting nicely where its supposed to be.
    Sump is off and the rocker cover is off as well.
    Thats what i was hoping for though Ecotech.
    Unfortunately no suck luck
    Andrew
    When you say the starter motor isnt jambed.. ...Did you pull it out? Then try turning the motor?
    Is it possible you could remove the gearbox easily? Maybe the input shaft is jambed / broken?
    Last resort something has seized in the 22R.
    Feb 2007
    Starter is as far our as i could get it. Couldnt get into the top bolt. But sitting where it is, it moves freely, nothing like its stuck in there.
    Its never easy to get a gearbox out
    I could try though and see how i go. Ill wait till after the mecanic gets here and has a look though.
    Thanks
    Andrew
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. Replies: 24
    Last Post: 18-04-2006, 02:42 PM
