Results 1 to 12 of 12
Thread: Oil Level sensor JZZ30 Soarer
    Default Oil Level sensor JZZ30 Soarer
    Anybody know how these work? looking at the wiring diagram they seem a simple idiot light, but I cannot figure out.
    wa
    Default Re: Oil Level sensor JZZ30 Soarer
    if they are the same as pretty much every other toyota its just a float that is hooked up to an idiot light
    maybe get a multimeter to confirm that you have continuity when the float is in the empty sump position
    That what i have thought, but testing with a multimeter showed the sensor has continuity reguardless of float position.
    wa
    maybe check for resistance while moving the float see if it changes
    ok just connected Ohms meter across the 2 terminals and moved the float up and down, there was no change in the value reguardless of the float position any other suggestion?
    Junior Member Domestic Engineer NeoNasty's Avatar
    Busted sensor?
    HZJ75, RS41, JZZ30
    I have this sensor wired up and working in my Wagon. From memory Mos had to use the control box for it from the halfcut.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    OK, so where is Mos, sounds like he could give me the help I need.
    Gee I 'm glad Toyota did n't include the control box in the wiring diagram I might have had problems getting to work........
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    I've connected the toyota sensor to the BMW computer and it seems to be one 'step' out..
    Ie when I get oil level sensor error on the dash, oil is low and when I get oil level low the oil level is okay...
    I had a play with meter and got the same results, so gave up and am dealing with it
    BMWTurbo, is your sensor error on the dash an idiot light or a guage?
    I think they're inductive, but haven't scoped so only a hypothesis.
    Newer clusters run these sensors directly. In older cars, such as a JZA70, there is a separate "ECU" for this sensor to allow it to connect to an idiot light. Rod's car has this additional ECU out of a JZA70 halfcut hooked up (even though the original engine was out of a JZZ30). I don't know if there is another source of these ECUs, but it's likely.
    Mos.
    Jan 2007
    Rogue, It's actualyl computer controlled. Has 'oil pressure sernsor fail', ' oil pressure low' and nothing if it's all okay...
  1. soarer dash in 1UZX22?
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 10-06-2006, 01:33 PM
  2. Dash error codes on Jzz30 Soarer
    By RLR in forum Tech and Conversions
    Last Post: 25-03-2006, 05:38 AM
