Results 1 to 15 of 16
Thread: M series bellhousing/transmission interchangeability
    Alberta
    Default M series bellhousing/transmission interchangeability
    I am looking at doing a manual conversion in my MX32 (4M). I know a W50 tranny/bellhousing from a MA46 should fit no problem, but how about a transmission or bellhousing from a MA61? A W55/58 would be much better IMO, not to meantion easier to source out.
    Thanks in advance,
    Josh
    Default Re: M series bellhousing/transmission interchangeability
    W40/W50 bellhousings will not fit on the later W5x alloy boxes, so what you want is a box and bellhousing from a later-model car with an M series engine (eg MA61, MZ10 etc). You will probably need to modify the gearbox crossmember as well, I know this is the case when upgrading an RA23 Celica from W50 to W58, but the tailshaft should fit with no mods.
    Short answer MA61 will fit (bolt to the engine) if you get the bellhosuing and gearbox from the MA61. MA70 (non turbo) will also fit.
    As said W40/W50 will not bolt up with the MA61/MA70 bellhousing.
    As for gearbox xmember I am unsure. MX62 gearbox xmember is the same width as MX32 (I used a MX32 auto xmember for an auto -> manual conversion once) so that might be an option...or may not
    Alberta
    Thanks for the info guys, thats very good news!
    One more question though: if I bolt on a W58 and bellhousing, will I still be able to use a W50 flywheel and starter motor? Or would a 5M flywheel bolt on to a 4M?
    Thanks again,
    Josh
    Flywheel and starter will be fine.
    What about the clutch assembly?
    (you want to know that too josh, right?)
    Quote Originally Posted by Screamn_Sleeka
    Clutch also = fine
    W40/W50 and W5x share the same input spline.
    Alberta
    Clutch also = fine
    The spline is the same, but the clutch diameter is bigger on the W5x (224mm vrs 236mm). Thus my question about the flywheels, as one would want the corresponding flywheel for the clutch used.
    Yes, I've posted pictures comparing 5me vs 7mge flywheels in the past
    Yes you will need to use the clutch hardware that suits the flywheel you have, as you have stated.
    If you use the clutch & pressure plate that suits the M series flywheel you have it will work with either a W40/W50 or a W5x
    Treat the clutch assembly as the clutch, pressure plate and flywheel and there shouldn't be issues
    Alberta
    So.... does that mean I CAN bolt a 5M-GE flywheel to the 4M? I have to source out a flywheel as well (obviously) and it would also be better/easier to get my hands on one of those.
    Once again, thanks for all the info guys! This is going to save me a lot of time measuring, trying, and messing up!
    Josh
    Junior Member Domestic Engineer Viper's Avatar
    Sorry, but slightly off topic here.
    Whats the PCD of the engine to bellhousing bolts?
    Just need to grab some for the engine stand.
    Sorry, best existing topic i could find
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
    M12 x 1.5 from memory.
    And thats thread pitch, not PCD
    User Conversion King
    NWA
    there is no PCD as the bolt holes arent on a circle
    hello
    Sorry, Thread PCD
    And thanks Cruz!!
    Quote Originally Posted by Viper
    Sorry, Thread PCD
    And thanks Cruz!!
    It still isn't called "Thread PCD" or "Thread Pitch Circle Diameter"
    Thread pitch and diameter, or perhaps thread designation might be more accurate
  1. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 12:51 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 06:14 PM
