i wasnt aware that was possible?
Fit an aftermarket LSD to a open diff S54 ?
1992 MR2 GT turbo
2009 Lexus IS-F
Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
Hence the question mark
Throwing it out there as a possibility ?
Having worked in an automatic transmission shop has made me realise I would love to specialise in manuals/diffs.
Ninja Edit : Ofcourse it's possible, that's why I suggested it
of course you can... makes 1/2 of the products listed here useless if you couldn't http://www.kaazusa.com/partinfo_japan.html
awesome, thanks very much guys!
there you go then
TRD is pretty freaking expensive but nevertheless various options means ill be able to find one at a good price somewhere
1992 MR2 GT turbo
2009 Lexus IS-F
hey man.... long time no chat.......
i got my v6 in and running..... ..............
Q?...... what temp does your 3vzfe sit on........ mine is anywhere from 85 -95....... so trying to figure if water pump is fukt.........but its not overheating just seems hot.. is all
grant......
2012 GT86
V6 powered 5th gen celica. Sadly moved on to build below
91 st185 aus delivered, V6 turb project,
2015 Kun26r hilux
hey man
i dont have a water temp gauge that shows me in exact degrees but, when everything was running well, the factory gauge goes up to the usual spot it did with the 3S and sits there without moving even slightly
im using a 5S-FE thermostat btw
1992 MR2 GT turbo
2009 Lexus IS-F
2012 GT86
2015 Kun26r hilux
no worries dude, yeah hope you get that sorted and there's no BHG!
1992 MR2 GT turbo
2009 Lexus IS-F
Paul woods has done some experimenting and the ZZW30 factory helical LSD fits into the S54 box. IF your able to locate a second hand spyder box, it might be a cheap option.
http://forums.twobrutal.com/showthread.php?t=11589
Or mini spool !
you wouldnt happen to have a spare rear gearbox mount from the MR2 would ya....
im going ahead with e153 gearbox conversion in the celica and need another mount to bolt to gearbox... on the rear of engine.... so driveshaft side of box.... front one i can use 184 mount...... top of gearbox/passenger side is a gt4 mount..... but the rear one i believe is a MR2 mount......
2012 GT86
2015 Kun26r hilux
thanks angelmon and knightrous, interesting info!
fibrewizard: im afraid i dont have a spare mount, you could try the MR2 forum
http://mrtwo.mine.nu/default.asp
1992 MR2 GT turbo
2009 Lexus IS-F
