Results 1 to 6 of 6
Thread: dry sump
    Melbourne Victoria
    Default dry sump
    how much hp can you normally pick up when you switch over to a dry sump system using a positive vacuum with no out side lines connected ,well i think its a positive vacuum
    Default Re: dry sump
    for drag racing (max hp) maybe a couple of percent.. like 1-3%? (iirc)
    but it's also stuff like oil heat, reliability etc...
    Pretty hard to answer, but OldCorollas is pretty right I think. As I mentioned on the other forum you want between 1/4 to 1/2 an atmosphere vacuum, etc.
    www.billzilla.org
    Toymods founding member #3
    I guess that'd depend on the motor...there's power required to drive the oil pump, vaccuum pumps and all the other gear, maybe more than a factory oil setup. On a 2000hp drag car, that's pretty irrelevant, on a 150hp 4A, that might be more than it's worth from a purely power-related perspective. I think where it really comes into its own is for temp control, surge control, etc...
    RM.
    how does having vac in the sump help power
    The boobs are back
    Quote Originally Posted by Mr DOHC
    Less windage on the crank, and the oil returns from the head & off the crank much better.
    www.billzilla.org
  1. Leaking Oil Sump Gasket on 4K ?
    By Tham in forum Tech and Conversions
    Last Post: 30-06-2006, 06:13 PM
  2. Sump position model guide (SPG#)
    Last Post: 31-01-2006, 02:15 PM
