Results 16 to 25 of 25
Thread: 20v 4age questions
    Default Re: 20v 4age questions
    thanks, I assume thats also valid for their race series? I am going to find out how much they are worth
    S.A
    Quote Originally Posted by feral4mr2
    the rings you will need to measure the ring gaps on the pistons, if the 1st one (top) is 1.2mm, 2nd 1.5mm, and the oil scrapers 2.8mm then you use the same rings as a smallport 4age piston which in ACL is part number C1806.STD (STD for standard bore, not oversized).
    if however the top ring gap is 1.5mm, then the C1741.STD ring kit is required (same as a bigport piston).
    have fun with the rebuild.
    Dont you mean ring thickness of 1.5mm????
    You need Mr Revhead from New Zealand, he can supply the correct Toyota HG.
    As for all the other parts:
    • Bearings - ACL Race
    • Rings - ACL (proseal = iron rings i thought? C = chrome)
    • Gaskets - TOYOTA
    i recommend the toyota gaskets, especially for intake manifold, oil pump and rear main seal housing as these are the lovely metal gasket types. Most other gaskets you can make up from gasket paper (as suggested)... but if you are going to the bother of getting a genuine Toyota HG and valve stem seals etc, then why not just get a full gasket kit from toyota?
    ... again, contact Mr Revhead (search the forums)
    Quote Originally Posted by 30psi 4agte
    i knew what i meant.
    i've only seen the inlet manifold gaskets in the metal style from toyota karl... ?
    New Zealand
    yeah contact me! NEXT YEAR im on holiday
    dont email me now, as im just gunna hit the big delte button when i get back
    use the gasket to suit the head.
    i can do a genuine headset for about $130nz delivered to you in oz.
    as for bearings i can also do genuine. however ACL race should be ok. i personally dont recomend thier standard bearing range though.
    and finaly yeah 20v rings are differnt from 16v rings, i can supply those too if needed.
    after the 8th...
    Western Cape, South Africa
    Cool Re: 20v 4age questions
    I have a stock 2005 model 1.3 Tazz which I want to modify to the 4age 20v silvertop - anyone done this or similar? I need all help I can get - not a oiled machanic yet!
    I have made sure of the fit and some upgrades needed
    Apparently the engine will fit on the existing mountings
    Need to get special side shafts
    Brakes I have already upgraded to RSi ventilated discs and calipers
    Management system
    Junior Member Domestic Engineer psychofox's Avatar
    Valve stem seals for 20V are different to 16V as the valve stem is smaller diameter (20V = 5m stem, 16V = 6mm stem).
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    T'ville, QLD
    thanks guys, i will talk to you soon mr rev head, and yeah after a bit of digging and searching i found the valve stemseals were different
    thanks all
    2T out 4A in....
    heres the link for ACLs 20v part numbers
    http://www.aclperformance.com.au/Toyota4A-GE4A-GEL.htm
    Last Post: 17-06-2008, 08:53 PM
  2. AE92 4AGE engine swap to 4AGZE!! Questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 10-10-2006, 06:00 PM
  3. Bigport 4AGE wiring questions
    By Nebuchernezzer in forum Tech and Conversions
    Last Post: 29-08-2006, 06:36 PM
  4. 4age 16v questions
    By mc68 in forum Tech and Conversions
    Last Post: 19-05-2006, 07:01 AM
  5. 4age in ke25 Questions
    By Megz in forum Tech and Conversions
    Last Post: 13-05-2006, 05:54 PM
