Results 1 to 15 of 25
Thread: 20v 4age questions
    T'ville, QLD
    Default 20v 4age questions
    hey guys
    i generally dont like starting tech threads cos chances somone has answered it else where
    i went down to beenleigh bearings yesterday and talked to them bout a rebuild kit for a 20v, the following things came up, there is no head gasket available separate of a valve regrind kit, and there doesnt appear to be any rings specifically for a 20v.
    now the questions
    1. WTF is a valve regrind kit?
    2. because all the 4a blocks are the same(excepting oil squirters) could i use a 16v HG on the 20v?
    3. i would assume same bore = same rings, is this the case or do they change cos of the different compression height of the 20v pissers?
    thanks
    luke
    2T out 4A in....
    Default Re: 20v 4age questions
    i've used a 16v HG on a 20v rebuild, there are minor difference between the 2 gaskets though, by memory small coolant hole differences. though i saw no harm in this.
    a VRS is normaly every gasket from the head gasket up. if they sell you a VRS for a 16v, it'll be no good for a 20v, different cam cover gasket required etc.
    the rings you will need to measure the ring gaps on the pistons, if the 1st one (top) is 1.2mm, 2nd 1.5mm, and the oil scrapers 2.8mm then you use the same rings as a smallport 4age piston which in ACL is part number C1806.STD (STD for standard bore, not oversized).
    if however the top ring gap is 1.5mm, then the C1741.STD ring kit is required (same as a bigport piston).
    have fun with the rebuild.
    p.s. i buy 0.8mm gasket paper and make my own oil pump, rear main seal cover etc. gaskets, and seals needed seperately. it saves a lot of cash on gasket kits!
    As feral4mr2 said, A Valve Regrind Set is all the gaskets from the HG up. ACL do a full rebuild kit (for a 16v definitely but Im fairly sure they do 20v as well) but it has to be put together as they need bearing specs etc. meaning that they cant organise it for you until you have pulled your engine down which is a PITA. That is, unless you know what size bearings you need.
    by rights it should be same bearings as a 7 rib bigport and the smallport (mains 5M1695 and conrod 4B1780), same front seal (NJ349) and rear crank (NJ001) seals and by memory same cam seals (NJ353).
    disclaimer, please check my part numbers as it's been a while.
    i am a Backyard Mechanic WiLo's Avatar
    Quote Originally Posted by feral4mr2
    might sound stupid but where do you get gasket paper from?
    havent seen it in supercheap or repco, although i havent exactly been looking for it
    milk and juice come in 2L, The cheapest wines come in 5L, the finest vodka comes in 1L
    Repco sell it but you would have to ask for it. Not to sure about Supercheap.
    yea they normaly keep it out the back in small square cuts or a big roll to buy by the meter.
    though i wouldnt bother asking at supercrap, they most probably wouldnt know what it is.
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    supercheap sells gasket paper. cant remember what section though. just ask, comes in big rolls.
    Junior Member Domestic Engineer psychofox's Avatar
    Yes you can use Smallport AE92 16V Rings (1.2/1.5/2.8) ACL Part Nos are: C1806 (standard) or PS1806 (Proseal)
    Main and Rod Bearings are also the same a AE92 small port. ACL also have a RACE range.
    Mains: 5M1695 (5M1695H for race series)
    Rods: 4B1780 (4B1780H for race series)
    Thrust: 2T1695
    When rebuilding a 20V head, the valve stem seals are the hard bit to get afaik you can only get genuine ones in Australia (awaits rebuttal....)
    For headgaskets, the 20V HG water channels are different to the 16V one. Sone have suggested a 7AFE is suitable, but I'd just buy a genuine one from Toyota, or as I did, buy a TRD one. I picked mine up for $100.
    Have a look at this thread about 20V headgaskets:
    http://www.toymods.net/forums/showthread.php?t=8330
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    T'ville, QLD
    thanks guys! = rep for all (even those discussing gasket paper)
    i shall go and talk to the lovely folk at toyota when i get a chance.
    re valve stem seals, i have heard that they are exactly the same as 16v ones (3s and 1g as well), is this the case?
    thanks again guys
    2T out 4A in....
    good thread. nice info guys !
    good to have this stuff in the files
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    For the intake manifold gasket, I have used Weet-Bix packet and some Permatex No.3 or No.4. I get bagged out for this, but it works.
    For everything else SILICONE!!!!!
    Quote Originally Posted by Jonny Rochester
    Nice!
    How many Weet-Bix does your car do? Mine does a whole box...
    arnt the valve stems meant to be the same as a Prius and an Echo?
    oh also does someone have a part number for oversized rod bearings?
    bearing part number is the same, but with .25, .50, .75 after it instead of .STD. all depends on what size over you are after.
    Last Post: 17-06-2008, 09:53 PM
  2. AE92 4AGE engine swap to 4AGZE!! Questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 10-10-2006, 07:00 PM
  3. Bigport 4AGE wiring questions
    By Nebuchernezzer in forum Tech and Conversions
    Last Post: 29-08-2006, 07:36 PM
  4. 4age 16v questions
    By mc68 in forum Tech and Conversions
    Last Post: 19-05-2006, 08:01 AM
  5. 4age in ke25 Questions
    By Megz in forum Tech and Conversions
    Last Post: 13-05-2006, 06:54 PM
