Results 1 to 10 of 10
Thread: 4ag sprinter
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Default 4ag sprinter
    hey, if i put a 4ag in my sprinter do i have to make up bigger fuel lines to take the pressure from the fuel injection?
    (i hope not)
    Junior Member Backyard Mechanic kugzs's Avatar
    Default Re: 4ag sprinter
    if there is a carby 4ac in there now then yes, you will need efi fuel lines.
    Got good condition 23/28 bonnet hinges? pm me
    You don't need to replace the solid fuel lines, but the rubber lines obviously need replacing with high pressure EFI fuel hose. And make sure you use some decent hose clamps on these.
    no backyard Domestic Engineer japlish's Avatar
    stock lines will be fine in your situation.
    i ran mine like that with no probs
    edit: damit bigworm your 2 fast!
    Jun 2006
    So.....i don't have to replace the steel fuel lines that go from the tank to the engine bay, but i should change the rubber hose in the engine bay to high pressure hose to be safe.
    yeah?
    correct. the old fuel hoses will blow out under the pressure.
    Jun 2006
    sweet. So i don't have to replace the lines from the tank to the engine bay
    Quote Originally Posted by Wedged'86
    yes
    but IMO anything bigger than the VL fuel pump would be advisable to have bigger fuel lines.. then again the VL fuel pump is capable of ..... XXX kw more than you need anyway
    good luck with it
    Jun 2006
    thanks alot guys, this has cleared up alot.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    stock lines are good for over 200RWKW, most 4a's are under that anyway
  1. 4ag into ma70 chassis
    By mdcmotorsports in forum Tech and Conversions
    Last Post: 01-12-2007, 12:02 PM
