Results 16 to 30 of 48
Thread: GUIDE timing belt and water pump replacement JZZ30 soarer 100K service
    Seen, but not heard Grease Monkey fingers's Avatar
    Default Re: GUIDE timing belt and water pump replacement JZZ30 soarer 100K service 56K :(
    Simply awesome! That will definately come in handy.
    + rep fo you.
    great write up. Definiltey would have taken some time.
    My car is a hell of a lot easier to work on than a Soarer!
    QUICKEST 1JZ'S IN OZ
    AU
    Awesome guide. Should be added to the FAQ section?
    + rep.
    West Australia
    by far the best guide ever, working through it now , about half way ...
    Love u Barned !!!!
    xoxx
    Yes rather helpful guide I must say. Just pulled the front of my 1j apart the other night.
    Got a question though. The hydraulic tensioner. Do these often wear and need replacing? Is it usual to get a little slack in the timing belt when you turn it back a little anti clockwise? Just working out if I need to replace it now seeing as though its only $133 from toyota :S.
    stidnam
    question:
    is the part number for the water pump the non hydro 2jz-gte one or what?
    West Australia
    Im personally having difficulty with :
    Step 5 replacing the seals
    5.1 Remove the lower sensor bolt with 5mm hex bit
    5.2 remove lower timing belt cog by using 2x6m bolts on either side of the cog, my bolts slightly touched the crank shaft so that as I tightened the bolts, it pulled the cog forward.
    When i place the 2x6m bolts in , and screw them in to touch the crank section, they bend outwards and start scoring the crank and doesnt move the cog at all ....
    anyone have any other DIY way of getting this off apart from using a puller of some sort (which i doubt could be used as there is no room behind the cog to get the arms of a puller in there)
    plz let me know im stuck !!!
    Mr coFF,
    Make a puller?
    Get a piece of flat bar, drill two M6 clearance holes in it, get some M6 bolts that are long enough to go into the pulley, but not long enough to hit the crank and then when you turn the M6 bolts, the pulley will come off
    Surely they have steel and drills and drill bits and bolts in WA?
    West Australia
    i wish we could get married wilbo .. seriously
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    i just used washers over the bolts when i did mine
    West Australia
    success !!!
    Havabeer is on the money , used a piece of flatbar and kept spacing out the 6M bolts till i got the cog right to the edge of the crank where it met with the flatbar.. then thanks to wilbo , used a 20mm socket and put it on the end of the crank to space the flatbar out from the cog and just kept on pulling ...
    woo hoo!
    Also another question !!! ....
    Seeing as it was so fucking hard for me to get the crank cog off the crank, how the shit do ya put it back on ? surely you dont use a mallot or something ?
    as per the guide, give it a wire brushing.
    give it a layer of oil.
    use a RUBBER mallet to tap it back on, just make sure you put it on straight.
    West Australia
    cool
    kinda hard to not put it on straight as the keyhole things have to line up for it to even go on .5 of a mm
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    im doing this to mine now (first time to ever replace timing belt ect) when i get my engine on TDC and the top timing pulleys aligned with the marks. The mark on the harmonic balencer is reading 5 on the bottem timing cover and yours is on ' 0 ' ??? just getting worried about everything lol
    you should line it up with the marks on the bottom timing cover first. i have found that my top marks could be a tiny bit off when the bottom was on zero. If you have skipped a tooth it will be 6deg different from memory. Some soarer guys were just skipping a tooth on the exhaust cam instead of buying adjustable cam gears
  1. 1JZGTE Water Pump removal... A question or 2...
    By ZZT231 in forum Tech and Conversions
    Last Post: 26-05-2006, 09:47 AM
