Page 1 of 4 123 ... LastLast
Results 1 to 15 of 59
Thread: Cost of Fully Rewiring a Car?
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    Default Cost of Fully Rewiring a Car?
    Just trying to get some figures here for the cost of such a process
    and as a lot of you are experts with the soldering iron, crimping tool and shrink wrap you can give me an idea.
    im talking the whole car, front to back all elelctrical wiring replaced with new, conduited and labelled accoringly, hidden wiring the engine bay etc. a pro job.
    has anyone ever tried such a feat? probably old 50's hot rodders are the ones to ask seeing as their wiring is probably fucked proper.
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
    sa
    Default Re: Cost of Fully Rewiring a Car?
    I got quoted 500$ for a complete rewire of my GZE ae82. That was through Adelaide based Fours 'n more. I think that's a quite reasonable price, though I havent gone through with it yet.
    Whoever wired my car really had no concept of how to do a proper job. It's appaling, though it does work flawlessly which is quite suprising.
    Are we talking as per factory, or as per race car, i.e. the essentials work.
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    i'd love to get something like that done. 500 does sound like a good price when you think of how much effort would be invovled. i assume an autoelectriction would also be a good place to check out a quote for something like this
    it all depends on what you want done. There are a few places around that will supply "replacement" wiring looms for cars, front to back. That would probably be the cheapest option.
    From there..... well the cost is arbitrary really; the specifics are needed to know how much it will cost, and then from there it depends on the person doing the job as to what they charge!
    In my opinion, if i got change from $1000 for a FULL FACTORY functional rewire with hidden wiring in the engine bay then i would be happy.
    It's not exactly the easiest thing to do, and it's most certainly a time consuming son-of-a-bitch!!
    If you were making things minimalistic it gets much easier.... but still not the most fun
    One day, when i finally get off my lazy arse and rewire the '28..... i'll let you know
    i would also suggest that $500 is not for a "complete" rewire of the entire car.
    That sounds more like a quote to rewire the engine and EFI systems.....
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    I agree with Karl there - $500 would be OMGWTFBBQfcukenwhoosh!!~1oneoneeleven for a complete rewire of the whole car. I even paid slightly more than that just to have my old 20V/Microtech wired up (but the end result was completely worth it).
    The Painless Wiring kits that I've seen around look pretty good, allowing you to have everything colour coded and with a new fuse box included etc, but you would still need a fair amount of automotive electrical knowledge to complete the job I would think.
    Something like their 12-circuit Pro Street harness would be a good option I reckon. Even better would be the universal Aussie version from Aussie Auto Loom retailing for around $550 from memory.
    Check these out...
    www.aussieautoloom.com.au
    www.painlesswiring.com
    Sydney NSW
    great response
    i was thinking the whole deal
    as per 'leaving the factory floor' kinda job
    there a lot of shit in my car thats old and hard and cracking
    plus a lot of shit that doesnt work (ie demisters, random switches, door sensors, etc etc)
    so getting the whole lot redone would really make me confident with the electricals
    im trying to gause the costs so when the new shell is prepped + painted and ready to be 'swapped out' with my current cars bits, i'll be able to have the blank shell newly pre-wired with plugs etc to just 'plug and play' everything in without worring about cracking/bending old taped up factory looms.
    1000 bucks for a decent job is quite resonable considering the work.
    considering ill be getting the efi/engine bay done separately (with special plugs to remove the engine quicker etc) the "interior/accessories" looms/wiring should be easier to do.
    then theres also the thought of moving all fuses relays etc into a central sealed box in the glovebox with close proximity to the other electrical conponents.
    is the custom work also pricey?
    Wierdo Pervert Grease Monkey fuzz!'s Avatar
    i've started re-wiring my 23.. tis amazing how simple the old girl is - just time consuming.. i got everything set up in front of the tv to help keep my mind off the chore as you don't exactly need to think much.. strip, crimp, solder, shrink, strip, crimp, solder, shrink... repeat ad nauseum..
    it cost me about $250 for plugs, relays, wire, shrink, etc.
    My Missus is a Domestic Engineer BradW's Avatar
    I am currently wiring up an FE holden for a guy. It is running a VK injected 6 cyl.
    It is a full custom wiring job (as the car is now A LOT different to what it was when it came out of the factory) with all wiring hidden in engine bay and a fuse and relay panel made to go under the dash.
    I have designed the system, drawn up the diagrams and made all the harnesses from scratch. So far I have spent about 20 hours on it and I still have to finish the dash harness, fit the harnesses to the car and hook up all the lights, etc. This is probably worth at least $2000.
    It is very time consuming to do it from scratch but copying a factory harness would be quicker and easier (read cheaper). $1000 would be a good price but I would be sceptical about a FULL rewire for $500.
    Brad
    Old Corollas never die...
    My KE30
    Quote Originally Posted by BradW
    yeah sounds right. it's not like you're paying for materials, you're paying for a the work involved.. as with everything on cars, just do it yourself. you'll learn a lot, feel rewarded and save money.
    the best part in my mind is being able to modify some of the electricals. eg. i've always hated the fact that the RA23s headlight switches run directly off the battery. on a rainy day i really want to have my headlights on so other cars can see me, but at the same time dread the possibility of forgetting to turn them off. this won't be a problem in the future.
    also, wiring is a lot nicer (cleaner) work than most things on the car. (you're not busting your knuckles open on a filthy chassis.)
    500 bucks would only be for the engine wiring
    id tell them to go .......... if they wanted the whole car wired from scratch meaning everything new for 500
    i do complete wiring from scratch about one every 5 months
    it takes 4 to 5 days
    this includes new fusebox
    wiper wiring which can be a pain
    headlights also a pain
    especially if u r using old factory switches with new relays
    unless u have actually done this sort of thing its hard to imagine taking 4 days
    but its usually a 2000 to 2500 dollar job especially if u want heavy duty wiring
    all hidden etc
    even to copy a harness for 1000 bucks is not really worth it
    once u open up a loom to see or read it it gets all messy and shit
    the only way to wire up a car from scratch is do it on car with all new gear
    most auto elect shops will not do it for under 2500 or even 3000 because its not worth it
    best bet is to ring around and get prices
    i have done old mustangs
    old datsun
    race cars
    rally cars
    4wds
    cobra kit cars
    all of them have been over 1500
    another easier way is with a painless wiring loom
    but even then theyre worth 500 bucks just for wiring kit
    it still takes 3 or so days to sort everything out like all the lil bugs etc
    so its still goin to cost over 1500 if the person charges accordingly
    so unless u know someone who can do u a favour then its not cheap
    i can do a very nice job with alot of wires hidden and with abit of extra work u can make it very very neat
    but u have to pay its all up to labour time
    Thanks for the price list sideshow, im now much more happy that i did my own wiring on the race car. But then again, as many people have alluded to that is much easier due to the fact that i only need the bare essentials. Infact, i only need a total of 12 fuses.
    Pity that the shops i went to didnt have anything other than red wire when i did mine :S
    im not being rude but u should spend bit more time making it nice and tidy
    the tidier it is the less hassles u have
    another thing i try not to use is the fuseboxes or holders with the push on terminals
    they are one of the most common probs of bad connections with terminals falling off
    the parts i buy are twice as dear but work much better
    plus i try not to use those gold stereo connectors that u screw the cable into
    on a car thats driven every day its very easy to get probs
    i recently rewired complete 240z for the east african safari rally in africa
    the car had to be finished very soon to get on boat
    i had bugger all time for testing
    so u have to check and tripple check everything
    all this takes time and that is where the money goes
    luckily i found out it had no wiring probs hehe
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    What fuseblocks/boxes do you use sideshow?
