Results 61 to 68 of 68
Thread: Introducing you to 1KD-FTV motor.
  1. #61
    wa
    Default Re: Introducing you to 1KD-FTV motor.
    If your injectors are leaking fuel internally the fuel will go into that pipe through the head and then return to your tank. That pipe is very brittle/easy to break and will leak the fuel into the top of your engine if the pipe or washers are not sealing 100%.
  2. #62
    Feb 2010
    singapore
    Quote Originally Posted by 2jzhilux View Post
    thank you sir. i am going to get a set of it and change them out in thet next couple of days.
    would you know where i can purchase a workshop manual for the 1KD-FTV?
  3. #63
    wa
    Pretty sure toyota would be the only place you could get them.
  4. #64
    Feb 2010
    singapore
    thanks a lot!
  5. #65
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    seeing this is a diesel thread i thought it fitting to add this,bad quility and not toyota but still awsome
    http://www.youtube.com/watch?v=QLB2bxYfJEg&NR=1
  6. #66
    the hybrid Backyard Mechanic Fish's Avatar
    western australia
    no can get from a few desiel shops. UD trucks rings a bell
    and yeap the injectors are spraying to much.
  7. #67
    Feb 2010
    singapore
    Quote Originally Posted by Fish View Post
    injectors are spraying too much?
    that brings to mind a question. why are the injectors for cylinder 1 and 2 the same, but injectors for cylinder 3 and 4 the same (but different part numbers from 1 & 2)
    could it be that they were installed wrongly?
  8. #68
    wa
    They are definately all the same, i have changed many and they are no different.
  1. Which motor for the RA23??
    By o_man_ra23 in forum Tech and Conversions
    Last Post: 26-07-2006, 07:58 PM
  2. V6 4-Runner Knocking Noises in 3V-Z motor...Help Needed
    By Toyo Truck in forum Tech and Conversions
    Last Post: 05-04-2006, 09:38 AM
  3. 20v starter motor
    By Selk in forum Tech and Conversions
    Last Post: 19-12-2005, 08:08 PM
  4. Replies: 3
    Last Post: 16-10-2005, 09:32 AM
