Results 1 to 9 of 9
Thread: Oil pressure then no oil pressure then oil pressure what the deal?
    Default Oil pressure then no oil pressure then oil pressure what the deal?
    I have a 4AGE that has in the last couple of days started playing silly buggers with the oil gauge. The pressure reads above the mid line then drops slightly when driving then returns to normal. It then dropped to a little and I mean a little over L. It then returned to normal then dropped again. This morning it idled fine after two days of no driving, the ndropped within five miuntes of driving to a little above low. I have recently had an oil service and there is plenty of oil in it. I did read in the Gregory's manual that the oilo pump may cause this to happen when faulty, or the oil regulator is stuffed. What is your opinion? Love to know if I am going to end up stranded or have a seized motor in the near future. By the way drove home this afternoon and the bastard satyed at normal the whole 30km home.
    Default Re: Oil pressure then no oil pressure then oil pressure what the deal?
    check wire to sensor and then the sensor. then gauge!
    what? Automotive Encyclopaedia EVOSTi's Avatar
    some people think the oil guages in toyotas arent real good quality so the best way to check it out is to put a proper guage on (not an aftermarket guage like autometer, a workshop guage) and see what happens. may be worth considering that there could be gunk in your sump ocasionally blocking the oil pickup.
    Or if the gunk is not blocking the pickup then maybe the sensor. Make sure you check for this and not just teh electrical side of the sensor.
    Sorry if that's what you meant kingmick.
    What brand of oil filter was fitted. Some non genuine filters are known to have faulty bypass valves.
    cheers Chuck.
    MS51Crown Coupe,
    also, unbeknown to me util a while ago now, cheaper oil filters can actually lower oil pressure, and the ability to maintain a constant reading. obviously depends on the material used in the filter...
    Quote Originally Posted by ChuckLandwehr
    cheers Chuck.
    Doesnt the filter just contain the anti-drainback valve?? the bypass valve should be part of the oil pump circuit.
    Check your sensor first, then start pulling things apart, start with the oil pump, and check your clearances.
    Was the oil pressure problem evident, before you had the oil and filter changed? If not then the most likely culprit is the oil filter, a real easy fix, and the first thing I would do. If the problem has persisted for some time, then you will have to look a bit deeper, guage, sender, and then into the oil pump.
    o man ra23, yes the good ones contain an anti drain back valve. All filters should contain some form of relief assembly. Most important when the filter becomes blocked, best to keep dirty oil flowing through your engine, than no oil at all.
    cheers Chuck.
    MS51Crown Coupe,
    another thought, it could be a seal on the oil pump that has failed, and loses pressure, more so when oil is hotter/thinner.
    but would start with new oil filter, as said before before looking at sensor/electrics ect
    did you do the service? what grade oil was put in? could also be to blame. (most likely not, but it is very cheap to change opposed to playing with the oil pump)
  1. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  2. Tappet Pressure how much is too much ?
    Last Post: 03-05-2006, 09:36 PM
  3. 1jz Oil Pressure
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 23-01-2006, 03:32 PM
  4. 3SGTE oil pressure maybe low?
    Last Post: 12-01-2006, 03:40 PM
  5. engine pinging
    Last Post: 15-12-2005, 12:15 PM
