Page 1 of 11 123 ... LastLast
Results 1 to 15 of 158
Thread: 1G-GTE tech info/diagrams
    User Conversion King
    NWA
    Post 1G-GTE tech info/diagrams
    a bit of a collaboration of 1G-GTE tech info seeing as the old forum info has dissapeared.
    firstly, the wiring diagrams.
    http://img157.imageshack.us/img157/8...ecusht1iq6.jpg
    http://img157.imageshack.us/img157/3...ecusht2jq1.jpg
    http://img71.imageshack.us/img71/738...ecusht3bc4.jpg
    http://img88.imageshack.us/img88/637...ecusht4ep9.jpg
    http://img88.imageshack.us/img88/875...ecusht5au5.jpg
    http://img99.imageshack.us/img99/560...ecusht6tg9.jpg
    torque settings
    Big end bearing: 500 kg.cm
    Cam shaft bearing cap: 150 kg.cm
    Camshatf Pulley Exaust:475 kg.cm
    Camshaft Pulley Intake:475 kg.cm
    Cylinder head bolt: 650 kg.cm
    Cylinder Head Distortion: 0.2mm (Clearance)
    Front camshaft pulley Bolt: 2200 kg.cm
    Main bearing bolt torque: 600 kg.cm
    Timing Belt tensioner bolt and nut: 220 kg.cm
    Timing Belt idler 370 kg.cm
    Following are Torque values for 1GGTE.
    Cylinder Head = 48ftlbs / 64nm
    Camshaft Retaining Caps = 14ftlbs / 19mn
    Cam Gears = 29-39ftlbs / 40-53mn
    Main BRG Caps = 43ftlbs / 59nm
    Con Rods = 36ftlbs / 49nm
    Harmonic Balancer = 130ftlbs / 177nm
    Flywheel Bolts = 54ftlbs / 74nm
    Exhaust manifold 2 Head = 19ftlbs / 25nm
    Inlet manifold 2 Head = 17ftlbs / 23nm
    Last edited by brett_celicacoupe; 04-08-2006 at 07:30 PM. Reason: because it would seem people using 1960's apple computers are too lazy to scroll across :rolleyes:
    hello
    NWA
    Default Re: 1G-GTE tech info/diagrams
    some info from "the_chuckster's " website
    Spark Plugs (require 17mm socket to remove):
    ND (NipponDenso) - PQ20R-P8
    NGK - BCPR6EP-N-8
    Denso K20PRU1
    Oil Filter:
    Toyota - 15801-44011
    Ryco - Z418 (same as ST-185 3S-GTE, 7M-GE, Lexus LS200)
    Valvoline - V022 (same as V6 Camry)
    Oil (engine):
    Mobil 1
    Coolant (engine):
    Oil (Gearbox):
    Manual (W58):
    Auto (A340e):
    Injectors:
    Denso (?) 23250-70040 - yellow top, top feed (no barb) ("7F19" on other side from part number)
    Ignition:
    Toyota (Denso) Coil w/Ignitor 19070-70150 (Denso 101311-4901) EW
    which consists of:
    Ignitor Assy - Toyota 89620-14420 (Denso 131300-0951) 095
    Coil = Toyota 90919-02146 (ND 029700-5551) 12V
    Airflow Meter:
    Nippondenso 22250-70170 (197100-3320)
    Timing Belt:
    Toyota 3568 79035 (same as GX81)
    Alternator Belt:
    Bosch - 4PK 1170
    Toyota - 99364-51170
    Alternator:
    Regulator built in
    Toyota 27060-70150
    12 V - 1600211-2820
    Denso "6G17" (stamped)
    Flywheel bolts:
    Toyota - 90105-10042 (don't reuse)
    Typical Engine Donor models:
    1G-Gxx used in - GZ20 1998 Soarer; MZ11 Soarer; GA70 Supra
    Gearbox:
    Auto - A340e (4speed ECT)
    Asin-Warner (is a BW box made under license)
    Model: 30 40LE
    Part 35000 - 24161
    Gearbox:
    Man - W58 (5sp Supra alloy)
    Turbo specifications:
    model: CT12 (Toyota)
    turbine inlet = 25mm
    turbine exhaust outlet = 42mm
    compressor inlet = 31mm
    compressor outlet (to intake manifold) = 29mm
    1G Engine Generation identifiers:
    Method 1 (ECU/Inj plugs)
    gen 1: Yellow ECU plugs and Yellow injectors. 0.50bar / 7psi.
    gen 2: Yellow ECU plugs and pale Green injectors. 0.62bar / 9psi
    gen 3: Grey ECU plugs and pale Green injectors. 0.75bar / 11psi
    Engine ECU:
    (Engine Control)
    1G-GT Toyota (Denso) 89661-14052 (175000-1140 12V) (sticker: ZV)
    connectors: 10pin, 18pin, 24pin
    Gearbox ECU:
    (Electronic Transmission Control)
    1G-GTEU Toyota (Aisin) 89530-24270 (ink stamp: 7F26 - serial number or ROM version?)
    connectors: 24pin
    hello
    NWA
    also the info regarding generation identification
    Version 1: Yellow ECU plugs and Yellow injectors. 0.50bar / 7psi.
    version 2: Yellow ECU plugs and pale Green injectors. 0.62bar / 9psi
    Version 3: Grey ECU plugs and pale Green injectors. 0.75bar / 11psi
    hello
    NWA
    1GGTE AFM is interchangeable with the 7MGE but the spring rate is different. ive run my 1g with the 7m AFM and i did notice it ping. i knew it would happen but i just wanted to confirm
    here is a pic of the gen3 ecu
    also a pic of the winged front sump found on GX81 chasers.
    hello
    NWA
    here is a useful little pic i drew a long time ago (for my own benefit)
    hello
    TAS
    Nicely collated info.
    What gen is the last diagram ( ecu plug) for?
    I'd just like to clarify on this. From what i've seen it's a little wrong. It should be better as this:
    Version 1 : Yellow ECU plugs, yellow injectors, W-A intercooler, 7psi
    Version 2 : Yellow ECU plugs, yellow injectors, A-A intercooler, 9psi
    Version 3 : Yellow or Grey ECU plugs, lime green injectors, A-A intercooler, 11psi
    Instead of ECU plug colour, the best way is to count the pins. I don't have the numbers handy, so i'll update it later. A Gen2 loom will run on a Gen1 ECU, but will complain about the water pump not being connected. Either of the Gen3 ECU's will be happy running on a Gen3 loom, i've not noticed any difference between the two.
    My Gen2 ECU would boost cut at about 14.5psi. My Gen3 ECU would boost cut at around 15psi. With 3 notches tighter on my factory AFM spring, my boost cut is a little over 18psi without many adverse affects on drivability.
    Junior Member Domestic Engineer mic*'s Avatar
    Quote Originally Posted by JustCallMeFrank
    Nathan, define: "many"
    Basically from this, i take it that the standard fuel mapping under boost is that rich that you can run an extra 3psi on ~same fuel.
    Is your fuel system stock?
    meh...
    Your a legend awesome post! Just in time too when I have to wire up a 1ggte in the next few weeks
    rep!
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    My fuel system consists of factory GA61 lines and Walbro external pump (my car had external from factory).
    "many" = occasionally my ECU when pottering around gets confused and wont come out of deceleration cutout, so you'll be slowing down slowly, go to accelerate again and it hesitates for half a second before jolting and taking off. I didn't notice this before, and both my ECU's do it, so I have to assume it goes into an odd part of the map or something to that effect.
    Junior Member Grease Monkey amon's Avatar
    NT
    My Gen2 ECU would boost cut at about 14.5psi. My Gen3 ECU would boost cut at around 15psi. With 3 notches tighter on my factory AFM spring, my boost cut is a little over 18psi without many adverse affects on drivability.[/QUOTE]
    Hey Pal,can you describe how you adjusted your AFM by 3 notches.
    Cheers Guy
    Sure thing. If you look at the top of your AFM, you'll see the panel which is siliconed on. Use a stanley blade or the like to cut the seal and pry the lid off. Inside you'll see a toothed wheel and a retaining clip. The wheel controls the spring tension.
    Mark where the tooth sits. I used a small dot of nail polish as its quite tough and easy to see against the black wheel. Loosen the retaining clip and try not to let the wheel just spin away. Move it against the direction it wants to turn the amount of teeth you want to tighten it by, I chose 3. Fasten the retaining clip to hold it in place.
    This worked fine for me, and the AFR's are still pig rich afterwards. Do this at your own risk, all Toyota ECU's tend to have their nuances, but given the way Toyota engines fuel on boost, a couple of teeth is unlikely to cause any major lean outs.
    NWA
    the last pic i put up was of the gen3 ecu 22pin plug plug.
    note; all the labels for each pin were attained by removing the ECU lid and quoting straight off the PCB board.
    hello
    MS
    When I get home I'll post the 3rd Gen pinout chart I made up when I was going to be doing the 1G swap. AFAIK it lits what pin goes where for most of the plugs.
    I'll put it in this space.
    RA65 SCCA Car (looking for a decent swap)
    NCP61 Daily Driver (pondering the practicalities of making it a SCP61)
    MS
    Sorry it took a couple days to find. All that stuff is on one of those easy to misplace jump drives....
    anyways heres the link to it.
    1GGTE Pinouts (3rd Gen)
    Its done in a .rtf format so most everyone should be able to open it.
  1. 4age tech docs
    By akmehd in forum Tech and Conversions
    Last Post: 07-06-2006, 03:23 PM
  2. Some general tech info about engines/tuning
    By Hen in forum Tech and Conversions
    Last Post: 03-01-2006, 01:39 PM
  3. html in the tech section
    Last Post: 28-12-2005, 11:49 PM
  4. Guidelines: Posting in Tech and Conversions
    Last Post: 20-09-2005, 05:42 PM
