if LED is on when key is off, the injector is open when key is off?
check voltage between +ve feed to injector plug and battery neg, for off, Acc and Ign positions.
you need +12 to injector plug when on and start, but NOT for off or Acc.
if that checks out, then it's issue with ECU grounding the injectors, which could be any number of things
