this seems a fairly useful link (off the site)
http://au.toyotaownersclub.com/forum...howtopic=11780
supposed to be www.modifiedlife.com very good site that one.
Originally Posted by damo101
sorry i forgot the "i"
found this site with US camry manuals while looking for pinous on an Camry dash dimmer
http://www.camrystuff.com/
Thanks for the work Rusty P, and Infotechplus!
Here are the manuals online: Aristo 2ZJ etc ...
1. Lexus GS300 Repair Manual (RM406).zip
2. Lexus GS300 Wiring Diagram Manual EWD171U.pdf
3. Lexus GS300 Wiring Harness Repair Manual RM1022E.pdf
(Right Click, Save As)
Happy Reading!
Wiring diagrams for Aristo 1991 1UZFE 2JZGE and 2JZGTE motors and transmission
http://home.exetel.com.au/monty/aris...1991 2jzge.zip
http://home.exetel.com.au/monty/aris...991 2jzgte.zip
http://home.exetel.com.au/monty/aris...o 1991 ect.zip
http://home.exetel.com.au/monty/aris...1991 1uzfe.zip
Jealousy is a curse
Wiring diagrams for Aristo 1997 engine ecu and ect
http://home.exetel.com.au/monty/aris...1997 2jzge.zip
http://home.exetel.com.au/monty/aris...997 2jzgte.zip
http://home.exetel.com.au/monty/aris... 2jzge ect.zip
Jealousy is a curse
hthttp://home.exetel.com.au/monty/ar...997 2jzgte.zip
Jealousy is a curse
Does anyone have the pinouts/wiring diagram for a 1JZGE VVTI? Think it's a JZX10#.
See ribfeast's post at the top of this page.
ribfeast's .mac address is 404ed
worth a shot: anyone have wiring diagrams of the RZ Hiace? specifcally the reverse light from an auto hiace lol -
(put a manual box in, and cannot find the wire(s) for the reverse lights.)
98 3rz-fe Hilux 4x4
This is the sort of thing u should trace before remove gboxes! But you should still be able to to it without wiring diagrams now!Originally Posted by urantia
You should be able to trace one wire from the auto gearbox auto position plug (body side of loom) directly to the reverse light bulb with a multimeter (e.g. battery disconnected, reverse light bulbs removed, multimeter in ohms, ~0Ohms). One side of the reverse lights will go to the auto gearbox position plug, one side will be ground.
Then connect the battery, put the key in on/run and check for the pin on the auto gearbox position plug that has +12V (Pick the thicker wire if more than two are there, the other maybe the neutral/park switch...), that will be the common for the auto gearbox position switch.
The reverse switch in the new manual gearbox will just be a switch, so connect one end to wire that goes to the reverse lights and the other to the power pin.
Or if you still have the auto gearbox you can work it off from that too Find the pins on the auto gearbox position selector that have ~0ohms when the auto gbox is in reverse
2JZ-GE Wiring Diagram: http://gallery2.plebeians.net/v/cars...rical.pdf.html
Here is the entire II1(Orange) plug traced.
Spreadsheet available here; http://gallery2.plebeians.net/d/2711...acdc3b70c6a26e
IJ1 (Grey) plug traced
Associated Spreadsheet: http://gallery2.plebeians.net/d/2711...acdc3b70c6a26e
And the 2JZGE ECU Connectors for reference (the ECU numbers on my spreadsheets)
That my friends is how ECU wiring diagrams are done, none of this crap pencilled onto paper and photos taken with camera phones.
