Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 272
Thread: wiring diagrams and pin outs for people who need them so help them and add more
    Default Re: wiring diagrams and pin outs for people who need them so help them and add more
    invid sorry man when I found it I just coped, and when I put it in here I forgot where it can from.
    sel
    anyone have a RED BEAMS 3SGE wiring n ECU pin out diagrams?
    Junior Member Domestic Engineer urantia's Avatar
    I do know one man who would definetly have it. I'm not sure if he hangs out on these forums or not, but he was known as charlie on the old forums.
    Possibly celicaRA45 may be able to help you out aswell.
    98 3rz-fe Hilux 4x4
    sel
    Smile Re: wiring diagrams and pin outs for people who need them so help them and add more
    Quote Originally Posted by urantia
    hmmm... charlie... what is his nick in old forum?! im searching there as well... but seem like luck is not by my side...
    celicaRA45... i try to pm him...
    thanks...
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    1987-1991 Camry w/ 3SFE and 2VZFE - Electrical Diagrams
    http://oregonstate.edu/~tongt/camry/90/90_EWD.pdf
    1987-1991 Camry w/ 3SFE and 2VZFE - Body Electrical Diagrams
    http://oregonstate.edu/~tongt/camry/...Electrical.pdf
    1992-1996 Camry w/ 5SFE, 3VZFE and 1MZFE - Electrical Diagrams
    http://www.turboninjas.com/camry/camry94wiring.pdf
    1992-1996 Camry w/ 5SFE, 3VZFE and 1MZFE - Body Electrical Diagrams
    http://www.turboninjas.com/camry/be.pdf
    1997-2001 Camry w/ 5SFE and 1MZFE - Electrical Wiring Diagrams
    http://rapidshare.de/files/23267650/99EWD.pdf.html
    1997-2001 Camry w/ 5SFE and 1MZFE - Body Electrical Wiring Diagrams
    2002-2006 Camry w/ 2AZFE and 1MZFE - Complete Electrical Diagrams
    http://rapidshare.de/files/23267350/02EWD.pdf.html
    2005-2006 Camry w/ 2AZFE and 1MZFE (updated for 2005 model revision) - Complete Electrical Diagrams
    http://oregonstate.edu/~tongt/camry/05/05EWD.pdf
    2007+ Camry w/ 2AZFE, Hybrid 2AZFXE and 2GRFE - Complete Electrical Diagrams
    http://rapidshare.de/files/23266928/07EWD.pdf.html
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    thanks guys good to c the thread being but to good use
    Anyone have one for a UZS141 crown? Specifically the power steering computer?
    Also does anyone know the naming conventions for the wiring colors?
    Eg Y-B could mean yellow with a black stripe, or could be blue, etc etc. I need to know what all the color abbreviations mean Cheers!
    244rwkw / 328hp @ 18psi
  8. #38
    Traditionalist Domestic Engineer parrot's Avatar
    I can help you out with the wiring diagrams for a 1988 Crown which has a PPS (progressive power steering computer) included in it. Don't know if it is your model. There is a lot of crap in that car! PM me your address if interested but wont be before Tuesday.
  9. #39
    Cheers mate PM sent. I basically have a PPS computer out of a UZS141 Crown and I need to know which of the 6 pins go where, so that I can retrofit it to control the steering in my Cressida's chaser steering rack. I'm hoping the speed signal from the Cressida's instrument cluster is compatible!
  10. #40
    Junior Member Grease Monkey MacroP's Avatar
    Quote Originally Posted by Ribfeast
    I have the PPS diagram from a xZZ31 Soarer. It might comparable as the car is similar vintage. PM your email and I'll shoot the pic across.
    MX83 1UZ Conversion. UZZ31 engine, UCF10 Sump, UZS131 Tranny and engine fan idler. Custom exhaust and 147rwKWs.
  11. #41
    Sorry, was giving the kids lunch.
    So these are for 1988 model vehicles.
    blue wires are coded L by the way
    Crown
    black/yellow to PPS solenoid
    violet/white to speed sensor
    white/black to earth
    black/red various, but essentially ECU Ig fuse, light retainer relay, door lock control relay
    Cressida
    red to PPS solenoid
    black to PPS solenoid
    green/blue (then violet/yellow) to speed sensor
    white/red ECU Ig fuse
  12. #42
    i think them all linked to a url, and all added into one post would be more user friendly, like a directory............
  13. #43
    I like Stuff Backyard Mechanic mikie's Avatar
    would anyone have the pinouts for a ae101 dash
    cheers Mike
  14. #44
    That diagram in your email did the trick MacroP, I now have speed sensitive steering in my Cressida! Used the light green wire with red stripe for my speed signal. Tapped in just where it goes into the JZX81 ECU. Thanks heaps champ!
  15. #45
    No worries dude. Cheers.
