Results 1 to 5 of 5
Thread: 4age in ke25 Questions
    ......................... Carport Converter
    Default 4age in ke25 Questions
    Hey guys, as some of you mite know i have a 4age 16v in my ke25, at the moment i have gone turbo and working out a few things. I also upgraded to 4agze injectors and it has a distributor and coil setup. I have been trying to work out this wiring situation. So at the moment i just decided to put my old 4age 16v loom in and get it running on the stock computer. I know it is gonna be rough as hell but it would be good to see if it starts. My quesitons are:
    1) If it does run, would i be able to get a 4agze computer and plug that in straight away and run that? Or are the pins different for the different computer?
    2) If not, could i get a 4agze loom and computer then use that to run my engine?
    3) Would i have to switch to coil packs and ignitors if i run a 4agze loom and computer??
    Thanks guys,
    Michael
    south australia
    Default Re: 4age in ke25 Questions
    considering there are a few varients on the 4age mangement, you would have to be careful as to which ECU and loom you were to run.
    things such as......
    - MAP vs AFM
    - Injector plugs
    - ECU plugs
    - CAS
    - DLi ignition
    are just a few things to think about. i would try to source a GZE loom and ECU. i think you will find that the GZE ECU will handle forced indiction alot better than the atmo ECU. although i think that the atmo ECU MAY be able to handle a small amount of boost.
    depending on the model loom that you get, you may be able to retain your dizzy. i think there was a model GZE that had a dizzy from factory
    I got gze coils, and i am getting ignitors. So it would just depend on map or AFM? Or if i get coils to i have to get dli for it?
    Michael
    south australia
    yeah. you will need the crank angle sensor if you intend to use the dual coil setup
    Yeah i know that. I can existing one... Wat are DLI's again?
    MIchael
    Last Post: 17-06-2008, 09:53 PM
  2. 4AGE head on 4ac block
    By Dylan_ae86 in forum Tech and Conversions
    Last Post: 09-05-2006, 08:33 PM
  3. 4AGE cooling system - an observation
    By roadsailing in forum Tech and Conversions
    Last Post: 18-12-2005, 12:01 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 05:51 PM
