Results 16 to 18 of 18
Thread: 4AGZE piston rings?
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    Default Re: 4AGZE piston rings?
    Yes the 8.0:1 uses are 1.5mm top ring, where the 8.9:1 uses a 1.2mm top ring.
    Now 9AGTE 410kw atw
    Learner / modder / Backyard Mechanic PrettyCoolWagon's Avatar
    Aug 2009
    Thanks Bazda pos - rep
    A warning to all others! Backyard Mechanic
    Dec 2009
    CA
    I was told by a very reputable company that recently did the machine work on my adub 4agze rebuild that NPR makes the rings for Toyota, and those are generally the only ones they ever use. I had a set of them in hand during the machine work, and were going to use them until a specialty coating company screwed up my original pistons. Since I then had to get new pistons I decided to go ahead and get some oversize ones, and have the block bored out. When I went to check on new NPR rings for the plus size pistons I found out that there were virtually none in stock anywhere in the US. Plenty of standard size, but no plus sizes, and that was apparently normal stock conditions. How does that make any sense?! Has it gotten to the point where all US 4agze blocks are assumed to have already been bored out by now, and that they now all require sleeves, and might as well use standard size pistons?!
    Anyway, I then had to go for Toyota rings, and found out that they cost an arm and a leg compared to the NPR rings. Fortunately, the coating company was paying for these. When I got them I checked them against the standard size NPR rings, and other than a couple of slightly different markings near the end of each compression and scraper ring, which would have no effect upon their performance, they looked identical, not that that necessarily means a lot. What was odd, however, was that the oil scraper rings were designed in opposite manners. The Toyota rings aligned the flexible oil scraper rings with vertically shaped waves, and the NPR rings had horizontally shaped ones. I haven't heard that one design is any better, or different than the other, but I might check on it, just to see what is said about it, if anything.
    So long and thanks for all the fish!
  1. 4AGZE bigport and smallport piston rings - are they the same??
    By cam_ra40 in forum Tech and Conversions
    Last Post: 22-02-2011, 07:20 PM
  2. 2 type of 2t piston rings?
    By rotorat in forum Tech and Conversions
    Last Post: 09-09-2010, 07:06 PM
  3. Fried Piston Rings?
    By H1TMAN in forum Tech and Conversions
    Last Post: 05-11-2008, 05:39 PM
  4. 1G-GTE piston rings
    Last Post: 12-10-2007, 09:56 AM
