Results 1 to 5 of 5
Thread: 1JZ-GTE from JZS171 Crown wiring diagram?
    May 2010
    Moscow
    Default 1JZ-GTE from JZS171 Crown wiring diagram?
    I could finally figure out what has happened to ask the right question. Sorry for that topic with 5-spd a/t.
    So I ordered a full set of 1JZ-GTE from Japan, including wiring harness, ECU, engine and gearbox. It turned out (too late 'cause no one paid too much attention to electrics when physically installing the engine) that gearbox's connectors don't fit the rest of the harness.
    It eventually become evident that the engine is from a 1999-2003 JZS171 Crown while the gearbox is from 1998-2001 JZX100 Chaser.
    So I'm now in 2 troubles:
    1). None of the 1JZ-GTE wiring diagrams found in the web, or at least pin diagrams fit. They all show 4 connectors while the ECU 89661-3A660 have 5. So I can not even guess how to power it up.
    2). I don't know what to do to the gearbox either. If I had its connectors pinout I would decide if I can convert one type of connectors to the other ones. Otherwise my best guess is to buy one more a/t which is extremely rare as I know so far.
    Has anyone dealt with this exact modification of 1JZ? Or even guess where to find/d'load/buy/steal/etc the diagrams I need? Any minds are appreciated.
    Default Re: 1JZ-GTE from JZS171 Crown wiring diagram?
    Hi George
    I just happen to have the JZS171 wiring book in front of me PM your email to me and I can send some pictures
    Jealousy is a curse
    May 2010
    Moscow
    Awesome mate! PM is on its way. Sorry I can't give something in return so far, though I received so many helpful messages from you.
    May 2010
    Moscow
    Problem solved, madmont's diagram fits the harness perfectly. If anyone needs it PM me your email.
    Aug 2015
    berbice
    hello all i am doing a swap to my is200 with this jzs171 engine. will love to have some info a the jzs171 ecu wiring
  1. wiring diagram for AE111
    By tomcat in forum Tech and Conversions
    Last Post: 09-10-2006, 09:55 PM
  2. Needed! - RA63 Wiring Diagram
    By Spectre in forum Tech and Conversions
    Last Post: 06-09-2006, 11:54 AM
  3. wiring diagram ra28
    By Omegaman in forum Tech and Conversions
    Last Post: 09-03-2006, 10:51 PM
