Results 1 to 15 of 30
Thread: What Coilpacks fits 4age 16v?
    Mar 2010
    Default What Coilpacks fits 4age 16v?
    As im gettin a new ecu that has 4 ignition outputs i figure ill get rid of the old waste spark stuff. Ive seen a few pics of 16v heads running coilpacks and want to know wit ones they are and what they came out of.
    Default Re: What Coilpacks fits 4age 16v?
    I believe I've heard of 1NZFE COP being used on 4AGEs before.
    Edit: I mis-read this at first, the coil packs people run are usually just 4AGZE ones.
    Mar 2010
    I want the ones that sit on top of the engine on each cyl.
    I asked toyota in mornington what the part number was of if they coup help me but tubbster there didnt want to get up to help so anyone here got a part number or idea where to get them?
    2nzfe coilpacks from a yaris fit with a small adapter plate for them to bolt to. run 3ms dwell for them.
    Junior Member Backyard Mechanic manny's Avatar
    These are a for a 20V, not sure how suitable for a 16V
    http://s-86.com/s-coilpacks.html
    GSE20 IS250 - daily
    Mar 2010
    yeh i saw that, where can i get the adap plate for the 2nzfe from?
    Apr 2008
    http://www.toymods.org.au/forums/showthread.php?t=59129
    last 2 pic on the first post. according to him they are 1zz coilpack
    Mar 2010
    AH! i saw that ages ago but couldnt find it again.
    Again dose this set up require adap plate or has he just taped into the cover? anyone know where i can get some 1zz packs from?
    S14 saliva ones fit with minor work to hold them in place
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Mar 2010
    whats COP stand for in this? coil over plug? i keep reading it but dont 100% understand it.
    Quote Originally Posted by PRIMRK View Post
    Correct.
    Coilpacks are basically a bunch of coils grouped together with no distributor, one coil for each cylinder (or pairs, depending on the ignition setup), with high-tension lead from the coilpacks to the spark-plugs. 4AGZEs are coil-pack, for instance, as are a lot of Ecotec Commodores.
    COPs (Coil On Plug) basically remove the HT wire and place the coil itself directly on top of the spark-plug, so there is an individual coil for every cylinder and no high-tension wiring at all.
    Do these provide any performance gain over functioning/non-faulty HT leads?
    Mar 2010
    also what gain is there over the waste spark ignition?
    Apr 2010
    No performance gain, but better ignition control for things like launch control, anti-lag, 2 or 3 or more step rev control. But those things can be regarded as improved performance.
    the denso coils have been proven to handle 100hp/cyl, I use them due to their availability, reliability and ease of fitment.
  1. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
