http://www.club4ag.com/faq%20and%20t...ZE%2090-91.htm
http://www.club4ag.com/faq%20and%20t...ZE%20AE92a.htm
http://www.club4ag.com/faq%20and%20t...Comparison.htm
Bang bang bang. three in a row. should work for you!
Looking for 4AGZE AE101 wiring diagram.
I know that there is a 4AGZE wiring diagram on 4Agnet but it is a AE92 version i beleive as the colours of the wires are different to the loom i have.
I am looking for an exact AE101 4AGZE diagram if anybody has one or can help[ this would be much appreciated.
Please PM me if you can help
Originally Posted by The Witzl
Thanks slide86
But the first one i already have and the wire colours don't match up with my loom as i believe it is an AE92 GZE not a AE101 GZE in which i am looking for.
they must have posted it up wrong then cause it says ae101
what info do you need on the loom? i am pulling apart a GZE loom as we speak. Its all over my living room floor!
I'm in the process on doing a 4AGTE with the standard ECU.
Just trying to get an exact wiring diagram to make tracing the wires easier and working out what wires / plugs i can just not connect up and get it to still run. Also wether to use the standard fuse box with the engine or try and splice it into the original AE86 box and what exactly is required in the way of wire connections.
Just splice into the AE86 fuse box in the engine bay..... the AE86 box already has a socket for EFI main, you just have to wire it up and put a relay there.
The Club4ag wiring diagrams and ECU pinouts ARE CORRECT. I've used them a number of times..... there are only one or two variances here and there which you should be able to figure out if you actually know what you are doing.
Your actual ECU diagram is inside the panel of the ECU. If you open up the ECU you will see it behind the ECU's panel. Just be carefuld you don't static it when you open it.
Its always best to get the diagram from your ECU as the wiring is different depending on the region the ECU came from in Japan.
Limbo
I just looked on the inside of both sides of the ECU and there is nothing at all on both of them.
yeah. i just check in the ECU of my GZE engine and there isnt anything in there except chips and circuits!
That's unsual cos mine had the diagram on the inside of the ecu, and that's how i wired my 20v(or i should say my friend wired it).
He even showed me the diagram from the ECU........
see if this one helps you, it has a GZE diagram.
http://www.skynet.ie/~eireae86/PETER_4A-GZE_ECU.htm
Also try this site it has a few different diagrams that might be of help including Jap & US spec GZE
http://club4ag.com/technical_main.ht...s%20and%20Data
Yeha thanks Limbo
I have seen all of these but they aren't the exact wiring diagram, also i obviously will need the actual wiring schematic diagram with the colours in english not japanese.
Thanks anyway
BlueAE86 -
you've got to be be kidding me, right???
as stated before, those EXACT diagrams are what i use for EVERY SINGLE CONVERSION AND WIRING JOB i've done with relation to these motors.....
if you cant work it out from those, you need to hand it over to someone who can.
all the wiring colours are there dude, can you read????
I know all the wire colours are there on the diagram that you put up and that is the one i have but the wire colours don't match up with my AE101 loom.
I am trying to get the exact diagram so as as to make sure of asll things.
No i am not an electrician but do have some basics inthis though.
