Results 1 to 9 of 9
Thread: AE86 KYB Adjustable Shocks??
    Junior Member Grease Monkey BlueAE86's Avatar
    Brisbane QLD
    Default AE86 KYB Adjustable Shocks??
    Hi
    Wondering what part number for the KYB adjustable shocks to suit with lowering of car approx 2-2.5" and also springs to suit recommended.
    using the standard stuts.
    Do they come in short stroke also?
    Where to buy them from and prices would be appreciated.
    Also does anybody know what other steering racks fit into an AE86 without any modifications?
    Default Re: AE86 KYB Adjustable Shocks??
    Partial answer:
    You can get all KYB products through Auto One stores.
    check out http://www.ajps.com.au/ they list short troke AGX shocks to suit AE86.
    I've got a pair of rear KYB shocks from an AW11 and some springs, if that's any help...I think they fit.
    RM.
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    a set of kyb celica st205 shocks will set you back about $170ish and there 50mm shorter. not adjustable, just the excel G, but they'll mach nicely with some stiffer springs (anything above about 5kg they get a bit bouncy)
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    thats for the front, rears use pergot 505. awseome shock, $100 for both munroe.
    but be warned, mega short stroke.
    TAS
    Also consider GABs, which I believe are made by KYB.
    Junior Member Grease Monkey craigy's Avatar
    I'm using KYB short stroke (set rate) shocks in my AE86. I think they are out of a AE101 corolla, let me know if you would like some part numbers.
    As far as I know they are readily available in Australia through any Auto Parts retailer.
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    thanks for the plug pube
    yeah i keep adjustable and non adjustable in stock, short stroke and normal, pm me with your need and ill let u know
    thanks
    David
    Cusco camber tops available for all early mac strut
