Results 1 to 7 of 7
Thread: Head gasket for a 2L diesel
    1uz 4wd Hilux Grease Monkey Dust's Avatar
    Default Head gasket for a 2L diesel
    Apologies if this is the wrong section for this post.
    I recently bought a 1984 diesel hilux with a turbo 2L diesel, it has a blown head gasket (yes I knew that when I bought it). Now I can get a head gasket for around $80, however would it be worth trying to get a copper head gasket for it? if so where would I purchase one?
    Yes I have googled long and hard, but am unable to find anything specific.
    Also I read that the 2L and the 2LT headgaskets are slightly different, how do I identify if I have a 2L or a 2LT, as it is not the original engine from the car.
    Any other suggestions for things I should take a look at or renew while the head is off? I am all ears. Never replaced a head gasket on a diesel before, am hopping it is relatively straight forward.
    Thanks for the help
    Justin.
    Default Re: Head gasket for a 2L diesel
    toyotasurf.asn.au has lots of useful information about the 2l and 2lt's.
    RA23 - Twincharged
    JZZ20 - Daily
    Thanks for the tip, I did find that site in my searching, unfortunately their search function is crappy and after 45 mins of reading numerous irrelevant posts, I gave up
    vic
    If you put a pic up of yr motor i,ll tell you what you have , make sure the turbo is in the pic .
    Dave
    Junior Member 1st year Apprentice topgun137's Avatar
    Jun 2007
    mate, im no expert at diesels or doing headgaskets but id suggest doing all the valve guides on a diesel that old, possibly new head studs if you can find them, and a good clean up of the head itself, going thru everything that opens and shuts..
    then u can enjoy driving it, in the places it was designed to go, a million miles from anywhere..without worrying if you are gonna need to work on that part of the engine anytime again soon..
    happy 4wding..
    Dust: have a chat or PM to Esteban (Lance) as he's tripped over the differences between NA and Turbo L-series diesels recently.
    sir Grease Monkey
    tasmania
    mate , don,t use a copper hg unless you o,ring the block or head .clean her up nice and use a std hg and replacing the guides is a must as they wear like buggery . but if you need copper hg for anything google ridgecrest in melbourne ,they make them for most engines. cheers bigwad
  1. 18rg head gasket fire ring diameters
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 04-01-2012, 01:41 PM
  2. Head gasket replacement question
    Last Post: 23-09-2008, 06:33 PM
