Results 1 to 2 of 2
Thread: Wrist Pins......
    oregon
    Exclamation Wrist Pins......
    I'm looking for 4 tapered wrist pins... the following are the specs I need
    exact diameter - 18.01mm, or .7090"
    exact length - 60mm
    mass under - 65 grams
    cost under $50 per pin
    I do have a custom set of pins "available" (if I want to spend $$$) that are only 55 grams, but their cost is $100 each
    Please post whatever information you have.... and TIA
    Default Re: Wrist Pins......
    taper out the stockers?
    the density of the materials that could be used is abotu the same, so really, you are just looking at the volume of metal left = weight.
    you could even calculate how much metal to remove to get to your specified weight
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 07:11 PM
  2. How To: remove pins from your plugs - the easy way.
    By TERRA Operative in forum Tech and Conversions
    Last Post: 09-06-2008, 01:00 PM
  3. plug pins on *A70 supra wiper motor
    By sheepers in forum Tech and Conversions
    Last Post: 04-03-2007, 06:52 AM
  4. 1JZ JZZ30 ECU D1 & FC COR Pins question
    By cptsideways in forum Tech and Conversions
    Last Post: 06-02-2007, 11:16 PM
  5. 2 pins flasher relay
    By CHB in forum Tech and Conversions
    Last Post: 19-04-2006, 01:15 PM
