Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 116
Thread: 3tc wont start please help
    Been there.. Done That Backyard Mechanic Cob604's Avatar
    Aug 2007
    Default Re: 3tc wont start please help
    hey guys i just took the rocker cover off & when 1 is at top dead center 4 ex valve just closed & 4 inlet is just opening
    & all the valves move in the right order 1342
    i tried today & it started to fire when i sprayed fuel down the carby, it wont fire when i do anything with the carby.
    ive tried the air fuel mixture & nothing
    ive tried moving the dizzy & nothing
    it must be fuel as it only fires when i spray fuel down it
    engine timing is right
    dizzy timing is right
    its got spark
    its got compression
    i tried jump starting it & thing (even with a fully recharged battery)
    its in neutral
    & the extractors are on
    so it must be fuel
    for a few seconds it fired continously when i was spraying fuel down the carby when i stoped spraying it went back to cranking
    thx
    Quote Originally Posted by roadkill
    When you get reaction like that it makes it all worthwhile.
    Bat mobil + 4age.. Engine painted, Fitting up now. Not long...
    Live life on the edge.
    Junior Member Grease Monkey Celica_73's Avatar
    As 79GT said
    make sure your carby solenoid has an ignition feed
    Have you check this! Unless I've missed it I can't see a result from this suggestion. If this solenoid isn't getting power it shuts the fuel off, main purpose is to stop "dieselling" when you turn the ignition off.
    Aug 2007
    hey guys
    yeah i thought of that today & gave it power & it makes a click when it gets power
    & nothing
    any way im thinking water in the fuel as there cant be much more
    so im going to buy get a full jery car of fuel & run a hose to the mechanical pump & try then
    that will rule out the pump & the fuel
    then it must be carby related
    as i sprayed carby cleaner down it today while cranking & it started firing continuosly but not fast enough to start
    thx guys
    Dude before you go spending $30 on 2 Litres of petrol just connect it up to the mechanical pump to make sure, wont take long at all and unless the mechanical one is cactus you can definantly rule it out of the equation. I dont know what type of electric pump it is but if is the one jeffro has explained then my money is that its the problem.
    If it works and its the electric fuel pump that was buggered then get a new low psi electric fuel pump and fuel pressure regulator just to keep an eye on things (a rough guideline is that it should be pushing no more than 3psi max to the carby).
    Mr Shabadoo.
    Daily JZX100
    the fuel pump in the car shouldnt be screwed. Just way to big for a 3tc. Pumping to much pressure, it may not solve the problem but its something that is easily fixed if the mechanical pump is handy plus it needs to be done anyway.
    When i had my 2tg in the car it was always lazy to start and fouled plugs regularly, i pointed my finger at the pump.
    Aug 2007
    Quote Originally Posted by joey
    yeah that sounds right
    any way how can the electric pump be the problem
    as the float is in the middle of the dot (as the manual says)
    & the extra fuel goes back to the tank via return line
    & when i turn it to on & te pump is pumping the float level is stable & doesnt even move
    i turn the pump off & crank for a bit & the engine sunks the fuel in, stop cranking & turn the pump on & it fill the float up to the dot & then stops???
    thx
    just do it. It needs to be done anyway!
    Most cars will start and run for a few seconds on a cap full (screw on cap off five litre oil container) of fuel poured down the throat of the carb. if you do this, have the choke open / off. and throttle wide open.....
    Since you are not totally sure of the ignition timing, have someone ready with an old blanket, bucket of water etc . just in case it backfires and shoots fire everywhere.
    if it starts, you will know that its fuel. if it doesnt, look further......
    Aug 2007
    PLEASE EXPLAIN HOW TE PUMP COULD STOP THE CAR FROM STARTING
    as the float is in the middle of the dot (As in the manual)
    & when i turn the pump on the float still stays the same
    then i turn it off & crank the float bowl goes down
    then i stop & turn the pump on & the float fills up & stops
    im thinking water in the tank
    im going to buy some new fuel & hook it up under the mechanical pump & run a hose into the jerry can & crank see what happens
    that will rule out the fuel & the pump if it doesnt start
    thx
    Aug 2007
    yeah jeffro i know it needs to be done so il do it next week, but i cant see why it will stop the engine starting
    i tried a cap of petrol down the carby today & it fired a few times then back to normal
    but i poured it down, with the throttle closed then cranked it
    ignition timing is right as i can spray carby cleaner down the throat & today i day it firing continously (but not running for a few seconds then back to cranking
    thx
    haev you opened up the carby yet?
    it sound slike the jets are blocked/rooted.
    Aug 2007
    i just rebuit the carby myself & down it exactly as the manual says
    i soaked everything except rubber ect in a petrol, carby cleaner, wd40 brew for 1 night for each section
    then cleaned & dried it out with a towel & then blew out all the passages & jets ect with compressed air
    the jets cant be blocked as when i turn the elecetric pump off & crank the float level goes down
    thx
    Quote Originally Posted by Cob604
    thx
    Lol, thats the funniest thing iv read all week.
    Aug 2007
    & when number 1 is at tdc ( intake valve closes & then half a turn) until timing marks line up the dizzy is pointing at number 1 spark plug lead on the top of the dizzy
    then 1342 clock wise around the dizzy
    thx
    just get a $30 dollar timing light and actually check it.
    but how do you know its 12 degrees BTDC or watever its ment to be?
    How you describe the way youve done it seems to me like its retarded. You should put the crank on 12 BTDC then install dizzy so te rotor button points at number one lead post.
    Atm your timing is probably more like 0.
  1. Bigport 4AGZE Cold Start Issue and Flat Spot
    By sbyder in forum Tech and Conversions
    Last Post: 12-05-2008, 09:01 PM
  2. MA70 woes...where to start?
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 02-04-2008, 08:05 AM
  3. Can't get the engine started at every 2nd hot start
    Last Post: 24-03-2008, 06:21 PM
  4. mr2 wont start
    By KARNAGE in forum Tech and Conversions
    Last Post: 09-03-2008, 08:10 PM
