Results 1 to 15 of 21
Thread: 4agze upgrades
    Default 4agze upgrades
    what are the options as far as aftermarket crank pulleys?
    how much and where from?
    also head gaskets?
    how much and wher from?
    btw its for a ae101 4agze.
    thanks.
    Default Re: 4agze upgrades
    what have you found in yoru search so far? (there is a bucketload of info around on them)
    blitz, Nevo, cusco etc.
    headgasket, what type. stock ones not doing the job? want copper? multilayer steel? composite?
    Junior Member Carport Converter 4agte's Avatar
    stock headgasket from toyota and id say nevo would be the best place to get a pulley from between $400-$550 i believe
    Genuine Hotty. Conversion King old_mr2's Avatar
    Nevo 175mm
    new $550
    Used $250 to $400
    www.nevo.biz
    New Zealand
    TRD do a steel gasket, in 0.5mm or 0.8mm stock is 1.2 so itll up the compression a bit though
    old lurker Grease Monkey
    do the abv mod so it gets the full boost
    and search around for a falcon pulley for the sc instead of buying a nevo
    think its the aircon pulley its the same belt type and itsnt that hard to fit
    and cost/performance it wins
    or http://nevo.biz/
    fear the chicks car
    Junior Member Backyard Mechanic sw20r's Avatar
    nevo is atleast $550 now
    Theres also a kit in america that does 178/180mm
    grab an ecu too microtech etc.. it will really open it up.
    thanks for the replys, given me some idea of how much.
    what price for a microtech ecu?
    you can get them for about $1500 installed, well worth the investment though as you can generally see upto 10-20AT the wheels KW figure.
    www.braidedlines.com
    His a favourable tuner in the castle hill area
    You'll find that john@nevo is a busy man. He works in Germany but dont let that pull you off. His kits are very good for their price and is garunteed to make you smile when you feel the power and hear that whine!
    Quote Originally Posted by sw20r
    indeed this is true i made about that with stock boost and without the afm and the pod mounted just off the inlet the whine was very loud it was schweet
    British Columbia, Canada
    NST makes a 180mm pulley. This is likely my next upgrade.
    http://www.nonstoptuning.com/pKitToyMR2GZ.htm
    289USD for the entire kit.
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    The nevo kit is made of a much higher grade aluminum alloy than the NST unit. Don't forget that a standard crank pulley is under plenty of stress. Larger ones experience plenty of load and are prone to failure if not installed correctly.
    180mm is getting very much on the large side for a GZE too.
    Yeah, don't go getting insane with the pulley sizing, remeber that you're taking the SC out of it's efficiency range. If you want an EA falcon pulley on your stock SC (giving you a 165mm drive and you keep your harmonic balancer), I can machine them on a swapover basis for about $80. I'm using that setup on my SC and it's making 11psi. After that start looking at intercooling and managment. A JayCar fuel/air adjuster is a good place to start if you can't afford the microtech, I'm about to get mine tuned and I'll post up dyno sheets afterwards.
    RM.
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    I cracked the centre of my custom 168mm pulley (stock inner steel part with alloy ring fitted)
    running 18psi on my AW11, partly by not having the crank bolt torqued enough. I imagine the aluminium would be even easier to wreck this way. Make sure you tighten that bolt up to 110ft-lbs and puts somethreadlock on it!
    Cheers, Nick.
    == 4AGZE SC14 Supercharged ==
    Bloody hell that's keen...18psi? I assume you're running an SC14?
    Come to think of it, I think adam mentioned your car...
    RM.
  1. 4AGZE into AE102 Corolla
    By birdie in forum Tech and Conversions
    Last Post: 02-02-2006, 05:35 PM
  2. oil capacity in 4agze
    By mojo_type in forum Tech and Conversions
    Last Post: 26-01-2006, 08:29 AM
  3. Toyota Odd Upgrades (TOU#) with other Marque Parts
    Last Post: 11-01-2006, 11:51 AM
  4. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 12:05 AM
  5. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 07:10 AM
