Results 1 to 4 of 4
Thread: Gen3 3S-GTE Rocker Cover Removal
    Default Gen3 3S-GTE Rocker Cover Removal
    The next chapter of my gen3 3sgte conversion is more frustrating than interesting.
    The rocker cover is leaking so the gasket needs to be changed. Apart from being held down by the usual bolts, there are three bolts on the timing belt backplate screwed into the rocker cover. These bolts are hiding under the cam gears. I really hope someone with a gen3 3sgte has removed the rocker cover without taking off the timing belt.
    I can't believe improvements to the 3sgte included a design that makes you redo the timing belt every time you want to remove the rocker cover. /end rant
    Default Re: Gen3 3S-GTE Rocker Cover Removal
    Are you sure about that?
    Don't think I've seen any toyota design that would force you to do that... Just doesn't make sense...
    Edit: I've seen a gen 3 3S cam cover come off without touching the front - you must be thinking of something else, or there's something else holding it...
    Mos.
    Yes it's ridiculous. To illustrate what I'm talking about:
    3 off them
    Forum Sponsor Conversion King
    mine came off no worries, you may have to remove the front cover but im pretty sure either the plate stays on the cam cover or the whole lot comes of without removing the belt or gears.
    its been over 6 months, but it wasn't difficult.
    ps no rockers in there dude, it aint no shitbox sr20.
    linden
  1. 2TG Rocker Cover Guide - With Pics
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-05-2015, 09:56 AM
  2. 3sgte rocker cover
    By gee120 in forum Tech and Conversions
    Last Post: 05-08-2007, 10:24 PM
  3. 2tg half moon rocker cover gasket
    By auzzi_17 in forum Tech and Conversions
    Last Post: 26-10-2006, 04:53 PM
  4. Which 3sg Gen rocker cover is this ?
    Last Post: 10-03-2006, 11:25 AM
